Thank you for reply.
Can you quantify the self-discharge of the AW 2900 and Eagletac 3400?
What Is the Voltage of batteries after any months of storage charged? Have you tested it?
No self-discharge quantification is possible because of the way I use my lights/cells, especially Li-Ion types. Furthermore, any self-discharge in storage is highly dependent on original cell quality and age/wear to begin with.
I have only maybe a couple 18650 cells outside of lights - intentionally so. I rotate thru all my 18650 lights (with cells already in them) at the rate of about one every day or two. Even the 3 or 4 cell 18650 lights will be used enough on certain days of the week to drop the voltage sufficiently for a recharge. I normally recharge at about 3.5-3.7 volts, but sometimes I recharge even above 4.0 volts. At night, I strongly prefer to leave the house with a fresh cell and what I expect to be the full runtime. I quickly check by seeing if the output at different levels is as expected. If not, I either take another light or swap out that cell(s) and charge. Maybe once a month I let a light run down until the low-battery indicator warns me - a reminder of the many different low-battery indicators.
Furthermore, the standby current of an electronic switch has been higher than the perceived self-discharge current - as observed on the couple 18650s that I do have outside of flashlights and then compared with the voltage level in a light that comes up on the rotation. Note that there is a natural drop in voltage after cessation of charge and removal from a charger. The extent of the voltage drop is an indication of the quality of the cell or it's age. I have no equipment to measure the actual capacity of 18650 cells, so I use only a voltage level as an indicator.
The lowest voltage I have observed in a LiIon cell (14500 or 10440) after about a week outside of a light is between 4.0 and 4.1volts - whereupon I recycled them. Fortunately I started with AW 18650s and although they are aging (couple years), none have been recycled yet. Generally I agree with the consensus that if a LiIon cell drops below 4.0 volts in a week, recycle it. Some forum members recommend the recycle cutoff of self-discharge outside of a light of a drop down to 4.10 volts in a week. Keep in mind that this is for aging cells, skipping the many low-quality 18650 cells being sold as new. It depends on the quality of the cell to begin with. If an 18650 cell becomes obviously warm during charging @ 1A or less, recycle it.
