Robocop
Moderator, *Mammoth Killer*
I have a cheap 2-AA light that I have cut down to use a single AA cell and a dorcy AAA board.The tail cap section is thicker than the body with a screw in clickie switch.There is enough room to bore out the tailcap section and slide it over the cut down body.With a little luck and epoxy I will be able to retain a threaded clickie switch on a light half the size.I have a Dremel tool but no lathe or mill.Anyone give some advice on the proper Dremel attatchment to use for removing some material from the inside of the larger tailcap?Can this even be done correctly using a Dremel tool?
