den331
hello just Got my ARE-c2 charger when fully charge using my multimeter the voltage reading is 4.27? is this voltage is too high for the 18650?
Mine terminates my batteries at 4.24 - 4.26volts as measured by my Fluke 87 so I'm not surprised by your readings. I use it only to charge my 4.30 and 4.35 voltage cells.
my meter read @ 4.26Volts at rest. i remembered my Nitecore i4 v2 charger terminates at 4.26 volts also. i have a dedicated 2 bay li ion charger xtar vp1 it terminates @ 4.22 volts.
would you suggest that i should stop using this charger for charging 18650 batteries? thank you
i only have NCR18650B panasonic. what batteries do you suggest that are rated @ 4.3 volts?
