Hi to all.
I am a complete newb when it comes to flashlights and batteries, so I have a newb question. I have a Nitecore p12 flashlight, powered by Nitecore NL183 18650 2300 mAh battery. The flashlight has a voltage indicator, which flashes every 2 seconds when the power is about 50%, and blinks rapidly when the power is low. It can also show the voltage accurate to 0.1 volts. I have read somewhere that an 18650 batteries should be recharged when they drop to 3.6V. My battery currently reads out 3.6V, and the indicator on the flashlight is blinking every two seconds, meaning it is on about 50% power.
I'm a bit confused. Should I recharge now, or wait until the indicator shows that the power is low?
Also, as the voltage drops, does the battery "life" drop, or the power of the output (lumens), or both?
I also have an Olight s15 running on a Trustfire 14500 battery. The flashlight does not have a voltage indicator, so I recharge the batteries when the light emmission stops. Is this wrong? Is there a difference how 18650s and 14500s should be treated?
Thanks.
Thanks.
