Hello everyone,
This is my first post so please bear with me! I did a quick search but figured I'd ask my question since I couldn't find exactly what I'm looking for. I know these are very newbie question... I work in a biology laboratory and I'm trying to build a setup to look at the behavioral response of insects to specific light (UV, visible, green, blue). It will essentially be a T (or Y) maze where the insect is loaded at the base of the tube apparatus and then must choose to go either right or left depending on the preference for the light (one 5mm LED at the end of each arm of the T/Y). There are TONS of 5mm LEDs from various manufactures. Can you recommend some that will be the most stable in terms of output and wavelength from one experiment to the other? In addition, I need to control the output of each LED (dim/brighten). There are potentiators but I'm not very familiar with the electronics behind everything. So any help there would be greatly appreciated. Any finally, what can I use to measure the light output of each LED? Any links to products would be great for all the above. Again, thanks for the help!
