Luxeon III mod for MAG 2D
Icarus
Belgium
I want to put a white Luxeon III with converter in my MAG 2D. I prefer to use 2D and/or 6AA NiMh batteries.
Any suggestions about which converter to use? BB750, BB1000, ...?
Chop
Louisiana
For a simple mod, I'd just go with a direct drive mod using 3 C cells. This makes for a very bright light.
If you want to use a converter, I'd keep it simple and go with a BadBoy1000. This wi6ll also make for a very bright light.
LukeK
TX
3 C's won't fit in the 2D body. It's 3 CR123's that fit with a properly sized tube to replace D's.
lambda
Iowa
[ QUOTE ]
[/ QUOTE ]
LukeK, yes, 3 C cells will fit in a 2D Mag.
Look HERE for an example. The instructions are a little outdated, but show how to make the easy 2D to 3C conversion.
ResQTech
NJ, USA
"Mix up a large batch of Artic Silver and give the first 1/2 inch of the battery tube a nice thick coat of epoxy all the way around."
What does that step do?
lambda
Iowa
[ QUOTE ]
[/ QUOTE ]
That keeps the heatsink in place and decreases the thermal path between heatsink and body. Also acts like a lubricant before setting up to help the heat sink slide into place.
LukeK
TX
[ QUOTE ]
[/ QUOTE ]
Huh, well whaddya know...
StoneDog
Suwanee, GA
Yeah, 3C's will fit with some slight modification (namely cutting down the spring and inserting 1" PVC to hold the batteries).
Jon
