Test/Review of Efest IMR18650 2500mAh (Purple) 2014
HKJ
Copenhagen, Denmark
[SIZE=+3]Efest IMR18650 2500mAh (Purple) 2014[/SIZE]
Official specifications:
  • Capacity: 2500mAh
  • Min. Capacity: 2400mAh
  • Nominal voltage: 3,6 - 3,7V
  • Charge voltage: 4,20V ±0,05
  • Discharge voltage: 2,75V
  • Max discharge current: 35A (14C)
  • Positive pole: Flat Top
  • Protection circuit (BMS): no (unprotected)
  • Diameter: 18,40mm ± 0,1
  • Height: 65,25mm ± 0,2
  • Weight: 48g ± 1
  • Charging methode: CC-CV
This is a very high current battery, but the 35A rating might be a bit optimistic.
These curves shows a very good battery, there is a good tracking between the batteries and not much capacity drop from 0.2A to 20A.
[SIZE=+3]Conclusion[/SIZE]
Usual a battery with unspecified cell will not get better rating than acceptable, but there is no doubt this is a very good cell that is used here.
[SIZE=+3]Notes and links[/SIZE]
The batteries was supplied by Akkuteile.de for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
TEEJ
NJ
Thanks for your review excellent job as usual!
:twothumbs
Patt
Belgium
I think it's the same cell as these ... "Samsung INR18650-25R 3.6V 2500mAh" ... :wtf::D both very very good... :rock::twothumbs
G.Brooks
Thank you for the review.
Will it be ok to my Olight M22 ,or there are better options ? Let's say I want only IMRs.
uniformsierra
Panasonic has some 2900mAh
Neither of the batteries are old style IMR chemistry, but uses more modern chemistry to get the higher capacity.
@ HKJ,
what makes you say this? what is the difference between the old style and the new?
what i am thinking is the tendency for manufacturers to use Nickle in their cells to help with capacity - is this what you mean?
PS - cheers for all your awesome effort in testing, you rock :rock:
