Only issue I had was with my V10R, which presumably uses the same driver as the V11R.
I once accidentally put in the battery the wrong way in my V10R. Even though it was only in for a second, that was enough to screw up the driver. The light still works, but the ramping is all messed up. Now 3/4 of the ring's turn ramps very slowly from barely lit to a dim moonlight. Then, in just a few degrees of turn, the ramp abruptly goes from moonlight to max.
NEVER put in the battery the wrong orientation in your V10 or V11... it may kill it.
