NITECORE -- Keep Innovating
Page 7 of 7 FirstFirst 1234567
Results 181 to 208 of 208
Thread: Test/Review of Charger Xtar VP2
  1. #181
    Feb 2007
    Toronto
    Default Re: Test/Review of Charger Xtar VP2
    Quote Originally Posted by sidecross View Post
    All my batteries are 18650 3100mAh and 3400mAh bought in groups of ten and now include 40 batteries. I have three lights that use 4 18650's, two lights that use two 18650's each, and the rest use single 18650's. I live in an earthquake and fire hazard area and want enough battery capacity for at least 10 days without power.
    I am quite surprised that people collect flashlights and yet seem to be timid about batteries, chargers, and their expense. A flashlight without the knowledge of battery technology is like some one who has a Ferrari and will only consider cheap fuel, oil, and maintenance for their car. I have enjoyed the excellent comments made on this thread.
    Having 40 batteries, what other chargers do you have? 4x xtar vp2? Lol
  2. #182
    Hello all,
    Apologies if this was covered elsewhere, as I did not easily find it.
    I am brand new to this hobby, I just received my new ZL SC600w MKIII HI with 3, unprotected NCR18650GA cells.
    The research I did lead to me also acquiring an XTAR VP2 charger which the question I have is related to that:
    From what I understand, the cells I bought are fully charged once they are at 4.2v, however, the charger indicates that the cell is at 4.2v, but the LED never changes from red to green, is this normal?
    Is this possibly due to the cell not having protective circuitry to create an open circuit for the charger?
    I let the cells sit in the charger for awhile (30m or so) while they were indicating 4.2v, and then pulled them and tested them with my DMM (Fluke 87) and both cells are measuring exactly 4.2v.
    Is there something I'm missing here?
  3. #183
    Jul 2012
    Quote Originally Posted by suponlight View Post
    Hello all,
    I have and use this particular charger, mine does change to green when fully charged. Do you have the voltage selection to 3.6 volts? If it is set to 3.8 volts the charger will not terminate until 4.35 volts.
  4. #184
    Thanks for the input, it looks like I just didn't have enough patience.
    After your reply I decided I was willing to potentially "sacrifice" one of my cells to see if it ever turned green and, it did.
    I'd be interested in knowing what takes it so long to terminate once it's at its rated voltage, it took nearly an hour.
  5. #185
    Flashaholic* oKtosiTe's Avatar
    Jan 2012
    Sweden
    Even if the cell may reach 4.2V under load, it may not have reached full charge (i.e. 4.2V idle).
    In other words the last few mAh take the longest to pump in to the battery.
  6. #186
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    You can just look at the red curves in the OP post, when they go horizontal the voltage has reached 4.2 volt, but they continue for some time, depending on the cell.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
  7. #187
    Thanks for the information guys!
    Hopefully my ignorance helps someone else.
  8. #188
    Nov 2013
    Idaho, USA
    My VP2 no longer charges. Warranty expired last month.
  9. #189
    Aug 2011
    Ocean State
    What seems to be the issue?
  10. #190
    Nov 2013
    Idaho, USA
    Quote Originally Posted by RI Chevy View Post
    No charge current. Fortunately, I have a SP1 as a backup charger.
  11. #191
    Aug 2011
    Ocean State
    Wow. My VP1 is still charging strong.
  12. #192
    Sep 2007
    MA
    Quote Originally Posted by SubLGT View Post
    Contact XTAR or where you purchased from. They may cover it. Both Channels out?
    Mine are still holding up, but I also bought a 3rd backup for some insanely cheap price on sale because it looks to me like they may stop making this model with the SV2 and all their VC models out now, and the new VP4 Plus. A pity I don't like their new look they have been rolling out across the line. I'm happy so far with how the SV2 works though, have it charging 2 26650 batteries at 2A each right now. I need to get a lot more runtime on it though for 18650 the VP2 is still my go to or my WP2H. For analyzing though the lineup of course is different; I don't really need more chargers, but better analyzers. I may just get another electronic load as the price of the top chargers move up.
  13. #193
    Two things: Might depend on the version you have...1st Gen (sold for $50 when launched and quickly dropped to $35) was recalled due to enclosures separating in temp extremes, and if you didn't recv' adequate notice of recall you may be able to exchange for a functional unit or get your's repaired gratis.
    Sometimes depends on where purchased e.g. if from a distributor, like illuminationgear for example, he might be willing to go to bat for you if just out of warranty...pays to ask.
  14. #194
    Nov 2013
    Idaho, USA
    After an overnight rest with the power supply disconnected from the charger, the VP2 is functioning correctly again. Hmmmmm, weird. Charged a 26650 at 1A and a 16340 at 0.25A
  15. #195
    Feb 2006
    USA
    The VP2 is my favorite and most used charger...a true workhorse.
  16. #196
    Sep 2007
    MA
    Hmmm... very strange. if it happens again check that the plug has a good connection, and the switch is properly positioned and not loose. Great to hear it's working, have not heard of any reliability problems with these.
  17. #197
    Aug 2011
    Ocean State
    Cool. Good to hear that it is "working" again.
  18. #198
    Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    Maybe the wall wart is going?
    Keep an eye on it, as they have to cost about .02 cents to make.
    My Opus BT-3400 came with a 3A wart that couldn't charge 4 cells at 1A, but was fine with 4 cells at 700mA and below. Got a new one and things are peachy.
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
  19. #199
    Nov 2013
    Idaho, USA
    Quote Originally Posted by ChrisGarrett View Post
    Maybe the wall wart is going?..
    Maybe. The display lit up normally, and battery voltage was displayed, but no current was flowing and the voltage was not ramping up.
  20. #200
    I have an Xtar VP2 that I just smoked(literally, smoke came out of it). Can anyone recommend a new 4 slot charger?
    Thanks.
  21. #201
    ven's Avatar
    Oct 2013
    Manchester UK
    Quote Originally Posted by Cioppino View Post
    Thanks.
    Check the opus bt c3100 v2.2 out, good value charger and can do your 4 cells at 1a each(up to 2a on bays 1+4)
  22. #202
    Oct 2013
    USA
    Please tell us more. What were you doing when this happened? Do you have photos of the internals so we can see what component(s) failed?
  23. #203
    Is the power supply 110-220V?
  24. #204
    Fyi, as an answer to my own question, I've been informed by a vendor that the power supply is 100-240V.
  25. #205
    Unenlightened
    Jun 2017
    Bayview Township, the other NorthShore
    HKJ, thanks for review.
    New to the world of 18650 sized Lithium batteries and their chargers.
    Need for home and recreational use higher efficiency torches has opened a new world.
    VP2 seems to be a durable and popular charger. Reasonable price. Overall looks to be a good value.
    On the wish list.
  26. #206
    Flashaholic marcosg's Avatar
    Jan 2014
    Maryland
    Hello,
    One quick question: Can I use the Ac adapter of the VP2 which is rated :
    50/60Hz 0.4max output 12V—1000mA
    On my SP1 which is rated 50/60Hz 0.35max output 12V—1000mA?
    they look pretty much the same, only difference is the input from 0.4 to 3.5.
    the output is the same. Just trying to save some outlets with so many ac adapters that I already have
  27. #207
    Oct 2013
    USA
    ^^^ Yes, just be sure that the barrel plug has the same polarity (almost always the tip is positive).
  28. #208
    Jan 2014
    Maryland
    Quote Originally Posted by Gauss163 View Post
    Thanks Gauss. The tips are the same on both.
