medic75142
- Joined
- Jul 28, 2012
- Messages
- 25
I work in security as a regular uniformed officer as well as, what most people call a bodyguard. I need a light that I can EDC and use when I'm in either roll. So I'm open to what you have to say.
Flashlight Recommendation Checklist
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__X__This will be mail-order or Online (location doesn't matter)<br />
<br />
<br />
2) Budget: An easy question, but you may change your mind after you answering the rest!<br />
____I don't know yet<br />
____Up to $25.<br />
____Up to $50.<br />
__x_Up to $100.<br />
____Up to $200.<br />
____Up to $300.<br />
____Essentially unlimited.<br />
<br />
3) Format<br />
____I am not sure, please help me decide.<br />
__x__I want a flashlight (hand held/self contained).<br />
____I want a self-contained headlamp.<br />
____I want a headlamp with an external pack/power source.<br />
____I want a mounted light (typically for a bicycle or vehicle)<br />
____I want a lantern/area light.<br />
____I want a portable spotlight (it may have an external power source).<br />
____Other ____________________________________________<br />
4) Size:<br />
<br />
____MICRO - Keychain size.<br />
____TINY - Every day carry (2-4 inches).<br />
__x__SMALL - Every day carry (4-7 inches).<br />
____MEDIUM - Holster/belt ring carry. (>7 inches)<br />
____LARGE - Big enough to need its own travel case.<br />
____I don't know/I don't care.<br />
<br />
5) Emitter/Light source:<br />
__x__LED (known for efficiency, longevity, and compactness)<br />
____Incandescent (known for superior color rendition)<br />
____HID (known for max output, but often at the expense of size)<br />
____I don't know.<br />
<br />
6) Manufacturer:<br />
__x__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.<br />
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).<br />
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).<br />
<br />
7) What power source do you want to use?<br />
____I intend to use "Primary"/Disposable <b>Alkaline</b> batteries based on the usual AAA/AA/C/D sized cells common to most stores.<br />
____I intend to use "Primary"/Disposable <b>Lithium</b> batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).<br />
____I intend to use Rechargeable cells[/B] (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.<br />
____I intend to use Rechargeable cells[/B] based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).<br />
____I want a light with an integrated rechargeable battery pack.<br />
__x__I don't know/I need more information on power sources.<br />
<br />
7a) If you have selected a rechargeable option<br />
____I want a light that plugs directly into the wall (literally with prongs built into the light)<br />
____I want a light that has a recharging adapter (your typical "wall wart")<br />
____I want a light that snaps into a cradle (usually mounted on a wall)<br />
____I want a separate/stand-alone charger (this involves removing the batteries to charge)<br />
_x__I don't care<br />
<br />
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is not a happy experience).<br />
<br />
____I want to navigate a dark room or read a map (1-10 lumens).<br />
____I want an indoor "blackout" light (15-50 lumens)<br />
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).<br />
____I want to illuminate my entire backyard or a campsite (150-300 lumens).<br />
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).<br />
__x__I want search and rescue type illumination (800+ lumens).<br />
____<b>SPECIAL NOTE: Burst/Turbo mode Category</b> - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.<br />
<br />
<br />
9) Flood vs Throw: Flood covers an area, Throw reaches out to a distance.<br />
<br />
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.<br />
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.<br />
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.<br />
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.<br />
__x__Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.<br />
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.<br />
<br />
9a) Distance: How far away will you typically need to see with this light? (check all that apply)<br />
____Less than 1 yard/meter (reading, other close work)<br />
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)<br />
____5-20 yards/meters (check out a noise in the backyard)<br />
____30-50 yards/meters (I have a big backyard)<br />
__x__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)<br />
____150+ yards (I am searching from a helicopter)<br />
<br />
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum continuous output).<br />
<br />
____Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)<br />
____30-60 minutes (I have plenty of batteries just ready to be changed)<br />
__x__90-120 minutes (Runtime is moderately important, but still not critical)<br />
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).<br />
<br />
11) Durability/Usage: Generally the old phrase "you get what you pay for" is very accurate for flashlights.<br />
____Not Important (A "night-stand" light).<br />
____Slightly Important (Walks around the neighborhood).<br />
____Very Important (Camping, Backpacking, Car Glove-box).<br />
__x__Critical (Police, Fire, Search & Rescue, Caving, Survival).<br />
<br />
12) Switch Size, Type, and location (choose all that apply):<br />
____Any size switch will do.<br />
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).<br />
____I want a forward clicky (Helpful for momentary activation and signaling).<br />
____I want a reverse clicky (For use with multi-mode/level lights).<br />
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).<br />
____I want a twisty switch (Tighten the head/tailcap to activate, and the light will stay on until the head/tailcap is loosened).<br />
____I want a body mounted switch (near the head, like on a Maglite).<br />
__x__I want a tail mounted switch (found on the majority of today's high end lights).<br />
____I want a remote switch (usually found on high-end bicycle headlights)<br />
____I don't care.<br />
____Other, please specify____________________.<br />
<br />
13) User Interface (UI) and mode selection. Select all that apply.<br />
<br />
____A simple on-off with only one output level is fine for me.<br />
____I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)<br />
__x__I want multiple light levels. (Some lights have 5-16 light levels.)<br />
____I want a programmable light.<br />
____I want a selector ring.<br />
__x__I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")<br />
____I want SOS mode. (blinks in ---...--- emergency pattern)<br />
____I want a beacon mode. (Regular flashes at full power to show location.)<br />
<br />
14)Material/Finish/Coating<br />
____Plastic/composite body (this may limit your choices significantly).<br />
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).<br />
____Stainless steel (durable, but much heavier than aluminum)<br />
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).<br />
__x__I don't know.<br />
____Other, please specify____________.<br />
<br />
15) Water resistance<br />
____None needed<br />
____IPX4 (Splash resistant)<br />
__x__IPX7 (Waterproof to 1 meter/30min)<br />
____IPX8 (Submersible to greater than 1 meter for 4 hours)<br />
<br />
16) Storage conditions<br />
____In house (temperature/climate controlled environment)<br />
____Emergency kit (long standby periods)<br />
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)<br />
__x__Other_____EDC_____________________________________<br />
<br />
17) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any/all below.<br />
<br />
____Red filter (for preserving night vision).<br />
____Other filter colors (Amber, Green, Blue, _________).<br />
____Dedicated R/G/B secondary LEDs.<br />
____"Hybrid" light (bright incandescent combined with long running LEDs)<br />
__x__Pocket/belt clip<br />
__x__Holster<br />
____Wrist/Neck Lanyardl2<br />
____Crenulated bezel<br />
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments[/QUOTE]<br/>
<br />
<br />
<br />
3) Format<br />
4) Size:<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
__x__Holster<br />
