drumgod
Hi all,
Well, I borrowed a digital camera from a buddy of mine. So, in between the hustle and bustle of the holiday season, I have taken a few picks of my meager flashlight mods. First up, a couple of 20W 12V MR16 based Mags. (Pics link to larger versions)
These are *really* simple mods to do. The lights themselves remain bone stock, so you can use them as they where before. (Why you would want to do this, I'm not sure. /ubbthreads/images/graemlins/tongue.gif )
I made my PR base adapters in a similar manner as documented HERE by Chief_Wiggum. There are a few differences though. The pin recepticles I used have a plated, fully enclosed body and gold (I think) contacts internally. For the negative recepticle I soldered directly to the PR bulb base. Also, I did not completly remove the base material. I left the glass like tail on the bulb and made use of the factory positive contact area.
After trimming down the positive wire a bit of solder is added for a PR base that looks stock from the back and has JB Weld potted pin recepticles on the front. The adapter is inserted into the lamp just like a regular bulb. The assembly order of the head components differs slightly. The main head must be screwed on, then the MR16 bulb inserted. Lastly, the lense bezel is screwed into place.
The bulbs I used are the Osram 12V 20W MR16s available at Lowes. They come packed individually and are labled "narrow spot" IIRC. There was a three-pack of similar bulbs available that I almost purchased, until I noticed that they are not as narrow a spot and they have a shorter stated lifetime. I bought a 50W spot from Home Depot. I was very disapointed in the quality and the output so I didn't finish the 2x7x123 4D Mag I was going to put it in.
The 4D in the pics is powered by 14 E2 Lithium AAs. The 4C is powered by 7 SF 123s. The SF C3 was the brightest light I owned until I made these mods. I included it in the beamshot for refence. The order l-r is C3->7x123->14xAA.
Some notes about the beamshot. I couldn't figure out how to set a fixed exposure level with the borrowed camera. So, individual shots of each of the beams would be useless. The picture above was taken on the ceiling of my livingroom with the lights on. These lights are pretty dang bright and have a HUGE, usable sidespill. All you can see in the pic is the hotspot of each beam. Curiously, the hotspot of the 7x123 is a bit larger than that of the 14xAA. At first I thought it was symtom of reflector variances but, after switching them, it apears to be a fuction of the driving voltage/amperage. (The wide spot doesn't follow the bulb.) While it's a bit hard to see in the picture, the 14xAA is a little brighter/whiter that the 7x123.
I really like the 7x123 in the 4C Mag. It has become my favorite light to grab when I know I'm gonna' need one. I still don't have any runtime data. I did run 7x123 down to competely empty but, I did it on accident and wasn't there to see it. /ubbthreads/images/graemlins/banghead.gif I guess that means heat isn't an issue! /ubbthreads/images/graemlins/grin.gif I keep thinking I forgot somthing... Oh well, I can always add later. If I get a chance, I'll post my first real LED mod later. (well, simple, but real.)
Thanks again to all,
See ya'
See ya'
