Need help with a regulated DC P/S for ecig/vaporizing devices
Og3r
Quick Backstory: I quit chewing tobacco and have started vaping. Before chewing tobacco I smoked, so it was an easy switch and I love it. Recently I started getting into sub ohm vaping or "Cloud Chasing" as it's also known. I understand the risks associated with it, and use Sony VTC5 batteries, don't drain the battery below 4v, and recharge frequently etc, but still there are risks associated with sub ohming. I would like to mitigate these risks by eliminating the battery altogether.
Project: I would like to build a regulated AC to DC powersupply with adjustable voltage and preferablly adjustable wattage that has at least 20amps (would prefer 30 though). I looked at getting a commercial unit, but they are expensive and heavier than hell. As this will be a stationary device to be used on a coffee table or computer desk, it doesn't have to be as small as a regular vapor mechanical mod, but it does need to be somewhat handheld. I was thinking about gutting a computer p/s, but I'm not sure if I can get the 20-30 amps I need to sub ohm with a .2 ohm coil. This doesn't need to be anything fancy, but I do plan on fabricating an attractive case or having something milled to put it in. Is something like this possible? If so where should I start.
Strangely I have yet to see something like this on the ecig market. They have passthrough devices, but they use a usb port which only has a 2amp output, and are not V/V, V/W. A device like this would not only eliminate exploding battery risks for cloud chasers, but would also eliminate battery voltage drop off, and constantly recharging their 18650 batteries.
Anyways, I would appreciate your thoughts and ideas. Once I've done enough research, and start on this project, I will create a tutorial of my build, for other cloud chasers concerned with safety, to utilize.
FRITZHID
Icelandic wastelands of Monico, WI
The combination of high amperage and variability is where you're gonna run into cost/size issues. Regulation circuitry for 30A will need to be heatsunk and to provide the current you need, either a large heavy transformer OR solid-state power conversion which again will require cooling.
I too am a vapor user but only a small 1.8ohm 1200mah pen. I've seen the larger c123 and 18650, etc units and have toyed with them a little bit. Best thing I found was using my Pace soldering station's, pulse heat output (2v @ 2-43A variable) but that thing is a tank at about 50#.
There are PS available but they are lab/industrial grade and not cheap.
If you do find a cheap one, I'd be weary of cheap/underrated components and failures.
Building one isn't hard but again, size and weight are going to be an issue.
what max/min voltages are you looking for? What kind of wattage are you hoping to achieve?
Can vape be separated from PS with minimal cord?
