Hey to all. Been a lurker on these forums for a while and learned a lot. So I decided to join for advice and to share what I know as well.
Any way here's the deal,
I have a 2004 Suzuki Grand Vitara 3door model. Bought it about two months ago from the first owner. The headlamps were badly off, I "restored" them and used it for a while until I was able to buy new OEM replacement headlamps which I fitted with Philips Extreme power bulbs (H4).
Where I'm from in the tropics (Trinidad, a small Caribbean island), we have lots of bad roads, dark roads, and weather (lots of rain) that can change at a moments notice. I usually drive home late at night, and in the wooded country areas, there is fog. So I bought the OEM fog lamp kit for this vehicle, however it did not come with bulbs :shrug: . It uses H3 bulbs. I was thinking of using selective yellow bulbs, but I'm not sure if there's any benefit.
I had Hella yellow H3 bulbs on my Suzuki Jimny before, they looked nice, and worked well (better than the stock bulbs), but I'm not convinced they helped much in inclement weather.
Another thing is, I can only use a yellow bulb since it is illegal to have colored lens fog lights ie.yellow lens fog lights, so that rules out using an overlay or painting the reflector.
So my questions are:
1. Is there anything better than the Philips H4 bulbs, I want to make sure I'm getting maximum output from my new (and costly) headlamps.
2. What H3 bulbs would you all recommend I use for the fog lamps. My options that I came down to are;
-CPI gold selective yellow
-Navra +50
-Osram fog breaker.
I'm not sure if the selective yellow would give me any advantage in poor weather conditions.
Would really like some input here on bulb choices, and any other helpful advice.
Thanks in advance!
-Navra +50
-Osram fog breaker.
Thanks in advance!
