gonefishing
- Joined
- Sep 18, 2012
- Messages
- 352
Looks pretty slick! I just ordered one in brass with the 219 emitter. I have an MBI that runs off of that cell and the output is impressive. Perfect size for keychain.
What happened to the 10280 bodies?
That 10250 mule looks awesome by the way....
10180 and 10280 batteries dropped out of production last year and are generally impossible to now get .... folks who don't already have cells, may be out of luck.
Here's mine:
Are there no plans for any battery manufacturers to restart production of these cells ?
Small capacity Li-Ion batteries need frequent cycling and don't seem to hold up over time too well, either :sigh:
I don't have inside information, but a production run of cells costs $15-50k, depending on size, etc. My sense with those cells is that they all came from the same run and when they finally sold out, had not sold quickly enough to justify a second run. It may also be possible that the factory closed, etc. In any case, the 10250s offer output, runtime, and size, so I'm pretty happy with them. So I havn't given up on the older sizes, but don't expect to see them again.
When buying my first peak back in '08 or so, I debated between the 180 and 280 size. As Kamerat says (and reading reviews at the time), 180 guys tend to complain about runtime, so I went with 280. I was still using that very first cell until last week (with good runtime and output) when I changed over to the 250. As with IMR, the key to longevity is recharging asap when you determine voltage is low. Cumulative time spent at low voltage speeds aging.
