FourSevens
Results 1 to 15 of 15
Thread: Acceptable resistance for good quality 18650?
    Default Acceptable resistance for good quality 18650?
    What would be acceptable resistance for 1.5 yr old cells, Panasonic green 3400 mah protected? around 60-70 recharge cycles at most.
    Also i have an ongoing debate with my friend, about charging current. He isisnt that charging at lests say 0.375ma would results in noticably higher charge capacity of the cell, compared to 1A.
    Is this true? did anyone measured obtained capacity at different charging current? 0.3, 0.5 vs 1A? thanks.
    Default Re: Acceptable resistance for good quality 18650?
    Quote Originally Posted by dazed1 View Post
    I think you meant 375 mA (or 0.375 A) there? Anyway your friend is wrong. In the case of Li-ions, proper charging (CC-CV) involves constant current for some time, then constant voltage. The charge current just determines how fast the bulk of the charge goes into the cell. That constant voltage (eg. 4.2V) determines how much charge goes in. The cell determines how much current it needs to 'saturate' itself to reach that voltage. Compare with a balloon: higher pressure -> more air goes into the balloon. But up the pressure too much, and it pops.
    When the charge current drops below some value (say, ~50 mA for 18650's?), charging is stopped. So obviously where that cutoff is, also determines how much charge goes in - but only a little.
    With NiCd's or NiMH's it's more complex, but basically a (proper) charger will detect a voltage peak while charging. Stop charging before that, and the cell isn't charged completely (regardless of charge current). Stop after that, and charging efficiency drops quickly to the point where you're just converting energy into heat.
    Your friend might still be right in his/her observations, though. Which could mean:
    * He/she is using really, really poor cells. Or
    * He/she is using a really dumb charger. Or
    * He/she saw that behavior with NiCd / NiMH's, and thinks it also applies to Li-ions (NOT! ).
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    The charge does mainly depends on charge voltage and charge termination current, only to a little degree on charge current.
    But according to LiIon manufacturer a lower charge current will charge more energy into the battery, as long as the voltage and termination current is the same.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Thanks guys. To make it simple (for example only)
    How much mah will each cell have after being fully charged, and will the volts drop under load be the same? assuming both are equal quality, and exactly the same internals and both charged on some ultra high end charger....
    a) Charged @0.350A
    b) Charged @1A
    Thanks. I need generals figures, not scientific or something, my friend insists that the energy will be quite a bit higher on the slower charged cell...
    Edit, one more thing, what is an general acceptable resistance? for NCR18650B protected after 1.5 years?
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    a) Charged @0.350A
    b) Charged @1A
    I do not have any numbers for different charge currents, only for different charge voltage and termination currents: http://lygte-info.dk/info/BatteryCha...rent%20UK.html
    I do not have the resistance either, but it will depends on battery usage and also on how you measure it.
    Thanks alot for your help!
    Dec 2002
    Dallas, TX
    I sell quite a few Panasonic 3400 mah unprotected cells.
    They start at ~ 60 milliohms when new.
    After 1.5 years of use, I would normally see a little over 100 milliohms.
    Protected cells have more Internal Resistance due to the protection circuit.
    LEDite
    108W UV Lights, 9W Handheld UV Lights available
    Bumping this old thread because I'm wondering as well. Most of my cells measure around 50-80 milliohms new. I have an Eagletac 3400 protected which is several years old, stored at 4.18V in my Jeep year-round -20°F-120°F or more...rarely used so it has taken a beating. I'm measuring around 210 milliohms.
    I came across this online and wondered if it's a good estimate:
    Milli-Ohm Battery Voltage Ranking
    75-150mOhm 3.6V Excellent
    150-250mOhm 3.6V Good
    250-350mOhm 3.6V Marginal
    350-500mOhm 3.6V Poor
    Above 500mOhm 3.6V Fail
    GOOD TINT!
    *Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    Isn't HKJ measuring in the .04 ohm range on some of the newer hybrids, for starters?
    I guess if and when I get a li-ion charger that gives me an indication of this characteristic, I'll start worrying about it. I actually put more value in the I.R. number that my Maha gives me, than I do the capacity values!
    Ignorance is bliss, perhaps?
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
    Quote Originally Posted by ChrisGarrett View Post
    You bet! I wish I knew nothing about IR and storing at high voltages. It's a lot more fun to just use 'em and abuse 'em. That's what I'm trying to do, but I'll run a refresh and test resistance now and then.
    GOOD TINT!
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Hello Markr6,
    High internal resistance results in lower voltage under load. If you cell started having a mid point voltage of say 3.7 volts under a "normal" load (I use a 1 amp load) and the internal resistance of the cell goes up, the voltage will drop.
    At some point the voltage will drop far enough that the cell will no longer be useful.
    Tom
    Behind every Great man there's always a woman rolling her eyes...
    Most batteries don't die - they are tortured to near death, then murdered...
    May 2013
    Washington State
    Here is pretty much one of the most simplest methods of diagnosing cells is question. You can find a few variations off this measurement method but it's still pretty sound with even todays cells. But cell IR has improved over the years so use this as a reference and not a rule set in stone.
    Measuring a battery’s internal resistance is simple. All you need is a 4 ohm 5W power resistor or similar and a multimeter. Four common 1W 1 Ohm resistors in series would work. If you aren’t measuring an 18650, choose a load resistance that will load the cell but not overload it. Capacity/3 should be ok.
    1) First, measure the battery’s voltage when fully charged and not hot. This is known as V1
    2) Next, connect your multimeter leads to each side of the resistor and briefly connect the resistor across the battery. Make note of the voltage reading, this is V2.
    3) Measure your resistor to get its precise resistance, this is R
    4) The battery’s internal resistance (Ri) is calculated with the formula:
    Ri = (V1-V2)*R/V2
    Example: cell measures 4.2V unloaded at rest, 4.0V when connected to a 4 ohm resistor and has an internal resistance of 200 mOhms (0.2 ohms)
    A new high quality 18650 battery will have an internal resistance under 100mOhms.
    A used up 18650 battery will have a resistance 400mOhms or more.
    Oct 2013
    USA
    Quote Originally Posted by m4a1usr View Post
    A couple remarks worth mentioning.
    1) IR is highly dependent on temperature and (less-so) on SOC (state-of-charge = %capacity). So do the IR test at temp closest to that of the target app, and do it above 20% SOC (= 80% DOD) since IR typically increases sharply below that (depending on temp), e.g. see the graph below.
    2) If the load-test is too brief then the measurement will not be accurate because it takes some time for the IR from internal diffusion processes to build up to steady-state (esp. for less healthy cells). Ideally one should test while simulating the type of load in your target app. A too brief test would only be relevant for high-frequency (pulsed) loads. Look up "Nyquist plot" to better understand the full impedance spectrum.
    Graph excerpted from p. 1-4 of Challenges and Solutions in Battery Fuel Gauging, by Yevgen Barsukov.
    Dec 2015
    Alameda, Cal.
    Your friends correct in a way. Lower amperage will generate less heat and get a bit higher capacity charge. It will also give more cycles over the life of the cell. If you don't mind waiting 6~10 hours per charge.
    Oct 2013
    USA
    Quote Originally Posted by Benny Boy View Post
    Lower amperage will ... get a bit higher capacity charge.
    Not necessarily. It depends on the charging algorithm, e.g. is the termination current fixed or a percentage of the charge current or some more complicated function? Is the charge algorithm pure CC/CV, or PWM or pulsed, etc? It's not easy to give a definitive answer without knowing such details.
