I just got my first charger -- a used MH-C9000 with 26 Powerex 2700s and some cases for $25 locally off craigslist, which I think is a lucky deal.
The Powerex 2700s aren't particularly useful to me, but I'm going to offer to let my girlfriend's sister have a crack at them for her 3 young kids. I'll get myself some Eneloops or other LSD. Before I ship off the Powerexes I'm trying to get them into good shape with Refresh & Analyze / Break-In modes. The charger manaul says:
What does this mean -- ( MAX( actual_capacities ) - MIN( actual_capacities ) ) <= ( 2700 * 0.05 )?
Also, when searching the forum re: this question I came across some posts where people were saying batteries should be discharged before being put through the break-in mode on this charger (maybe before the refresh & analyze mode too?). I didn't think of that, but it seems to make sense once I heard it. However, the manual says nothing of the kind. In fact it more or less explicitly tells you you can run refresh & analyze 3 times in a row, and run break-in mode 1-3 (or 4?) times in a row after that.
So what's the deal -- is it necessary or important to run discharge mode between break-in cycles and / or refresh & analyze cycles? If so, how could they not mention that in the manual? If you don't need to do it, then how does that work, pumping all of that current into already fully charged batteries?
I got a printed manual with the charger, but I immediately went to find a digital version. I couldn't find one on Maha's website, so I searched the web and at this point I've found 2 different versions of the manual, neither of which match my printed one. I'm sure they're mostly the same, but one difference I've noticed is the instructions for inserting batteries. My printed manual explicitly says to insert AAs positive end first and AAAs negative end first. This one communicates the same thing by illustration only and this one says to insert the negative end first, period. What's the significance of how you insert the battery? Is it just trying to tell you the easiest way to do it, or is there some more serious effect? And either way, why does it vary between these different versions of the manual?
So far I've been inserting AAs positive end first and haven't had any trouble. Sometimes it's tougher to get them out though. What's the best way to do that? Somewhere I saw someone say that this charger has a habit of ripping casings, and I could see how that would be, considering the snagging I'm running into when removing batteries. And it may just be a coincidence, but one of the batteries I got with the charger is missing the casing (should I recycle that one?).
Another difference is that my printed manual and the second PDF above say that refresh & analyze mode rests for two hours, while the first PDF above says it rests for one hour.
Thanks for your help
Group batteries with capacity within about +/- 5% of the rated capacity.
