justonething
- Joined
- Jul 18, 2014
- Messages
- 13
I'm quite new here and learning a hell of a lot from CPF.
Last week, my wife said to me her car was struggling to start. As I remember that her car battery must have been a few years old, I quickly made an appointment to have a new battery put in the next day. I also realised that the battery from my own car is getting on a bit (more than 3 years) and come to think of it, it was getting just a little bit slow in cranking the engine in the coldest of winter as well. Perhaps it will last the current winter but probably not the next.
Browsing through this forum, I came across a post from samgab: http://www.candlepowerforums.com/vb...ery-charger-maintainer-CTEK-vs-Battery-Tender; and I was impressed with the ctek mxs charger. I was hoping that this charger could possibly extend the life of my battery. After a bit of research, I decided to buy the MXS 5.0T from a dealer in Sydney. It came today and I must say that the packaging gives a feel of a quality product and thoughtfulness in design. Instead of coming in a blister pack that does absolutely nothing for me, It came with recyclable cardboard packaging and a small bag I could use to hold the charger and its accessories. Putting the charger on the battery right away, it went through the 1st 3 steps very quickly (i.e., desulphation, soft start, bulk charging) which means the battery wasn't flat. However, Step 4 absorption took probably close to 4 hours and was followed by step 5 analyse. It was then quickly followed by step 6 recond which took at least a couple of hours. The car started smoothly and quickly this evening when I went out, so far so good. What remains to be seen is if the battery will deliver the CCA that the car requires in the coldest of winter mornings.
While doing a bit of surfing on youtube, I came across this clip:http://www.youtube.com/watch?v=Oi8sUE9XCgA. The guy in the clip (Kent Bergsma) went through different battery testers quite thoroughly. The tester that I was most impressed with was something called a conductance tester. It gives you the CCA or CA of a car battery. It was small and quite easy to use. Apparently, it is also quite inexpensive to buy on Amazon. I'm not sure if it is exactly the same as the one he was using, but this one is called SOLAR BA7 100-1200 CCA Electronic Battery and System Tester (http://www.amazon.com/dp/B0015PI7A4/?tag=cpf0b6-20 ). It seems to do a little bit more than conductance testing, It can apparently test engine starting and alternator charging as well.
Perhaps a tester like the Solar would complement the charger that I've just got and can really tell me when to rejuvenate and when to replace the batteries.
I wonder if there is anyone with a bit of first hand experience or insight on either this tester or other similar testers and would like to share her/his thoughts?
Thanks in advance
Thanks in advance
