HDS Systems
Page 1 of 7 1234567 LastLast
Results 1 to 30 of 191
Thread: TNT P60 TripLED Surefire C2, 6P, Z2 high-power custom made hybrid modules/drop-ins...
    Tana's Avatar
    Mar 2011
    Bosnia & Herzegovina
    Cool TNT P60 TripLED Surefire C2, 6P, Z2 high-power custom made hybrid modules/drop-ins...
    P60 TripLED modules for Surefire C2, 6P, Z2 and similar P60/D26 type of Surefire (or clone) hosts
    NOTE: This is old thread, please email about new prices and corrections in offer... thanks...
    Hand machined/hand assembled, polished aluminum/brass hybrid build for lightweight class and improved heatsinking...
    Copper PCB with LEDs per choice (same as for e-series TripLEDs)...
    Three possible linear driver power outputs, 3 Amps, 4.2 Amps or 4.5 Amps on high...
    GITD tape around optics and GITD epoxy securing clear/narrow Carclo optics for some after-off night glow (can be chosen without GITD) (AquaBlue or GreenV10)
    LED choice per your liking: XPG2, XPE2 (cool white or neutral white or warm white), Nichia 219B or 219C (neutral white), XPL HI (cool white, neutral white, warm white), white LEDs, color LEDs - If I don't have them in stock I can order them...
    Specs:
    Output XPL HIat 4.5 Amps approx 1800 lumens
    Output XPL HIat 3 Amps approx 1200 lumens
    Output XPG2at 4.5 Amps approx 1400 lumens
    Output Nichia 219B D220 at 3 Amps - approx 800 lumens
    Output Nichia 219B D220 at 4.5 Amps - approx 1200 lumens
    Voltage range: 2.8-4.5 Volts
    (SINGLE LI-ION CELL USE ONLY, IMR 17650 IN NON-BORED BODY or 18650 IN BORED BODY)
    PLEASE DO NOT ASK IF IT WORKS WITH TWO PRIMARIES !!! DO NOT TRY TO RUN ON PRIMARY CELLS !!!
    PRICES:
    $140 Base model, XPG2 or XPE2 or 219B or 219C LED, 3Amp or 4.5Amp on high, Tana3 semi-programmable firmware, no moon, no thermal regulation...
    $162 Base model Plus, XPG2 or XPE2 or 219B or 219C LED, H17F/Luci2 firmware... 3Amp recommended high level but moon mode and thermal regulation...
    $192 Base model Plus with HACS switch, XPG2 or 219C LED, H17F/Luci2 firmware...
    $180 P60 TripLED with XPL HI with H17F/Luci2 firmware... TopGun without HACS switch...
    $210 P60 TripLED with XPL HI with H17F/Luci2 firmware + HACS switch... TopGun model with HACS switch...
    $190 P60 Quad with XPL HI with H17F/Luci2 firmware... TopGun without HACS switch...
    $220 P60 Quad with XPL HI with H17F/Luci2 firmware + HACS switch... TopGun model with HACS switch...
    NOTE: Availability of HACS switches is limited, might not have them in offer at any time... there are two alternatives on the market to my HACS, I'll provide necessary info... WILL NOT SELL HACS ON IT'S OWN !!! HACS is ONLY included if H17F driver is included in build, for linear 3Amp and 4.5Amp modules it's not an option...
    GITD dics behind optics is possible + GITD under 3/4 stubs on optics... $20 for each GITD disc installed, both TripLED or Quad... Glow inc. colors available (including daylight) and disc/stub GITD can be combined with same or different color for cool effects...
    If any specific color temp or tint is wanted, let me know, I'm sure we can find particular LEDs in enough quantity to have matched triple set and install in desired setup...
    Please allow 10-15 days to build and ship after order... with current pace I'll only be able to make about 3 per month - which could decrease/increase depending on e-series awaiting modding list...
    They are tested in my non-bored 6P and bored C2 - not sure about fitments in aftermarket hosts or cheaper Chinese hosts (negative spring might be needed for some setups like Solarforce)...
    Each requires a slim wrap in clear aluminum foil to make SNUG fitment into hosts - the "beauty" of P60 hosts... My C2's internal module hole is 22.15mm and 6P is 22.10mm - although it's easy to make the module to be as close to those dimensions so to AVOID use of foil, they will never transfer heat as good as the module that's tightly wrapped in pure metal aluminum foil no matter of it's external dimension - I'm machining these to 22.05mm to allow at least one layer of alu foil (will provide a needed piece to fit 22.15mm bore)... remember - it has to be TIGHT FIT to be able to pass as much heat away from LEDs...
    I have Glow, Inc. Green V10, Bright Blue (light blue) and Pure Blue (blue blue) GITD powder to use behind the optics stubs... optics is epoxied in place (like OR triple) and cannot be removed... for those wishing to use drilled optics with trits, you can request not to glue the optics in place but avoid using in hosts w/o it being secured as it could pop-out during use or if dropped (which is easy to fix - unscrew bezel and push it back, lol)...
    More info on HACS:
    http://www.candlepowerforums.com/vb/...25#post4625225
    Tana3 firmware:
    Except for PM, you can contact me with email (this is not my PayPal email):
    Flashaholic plaguem's Avatar
    Jun 2011
    Singapore, Shipping Portland Oregon
    Default Re: TNT P60 TripLED Surefire C2, 6P, Z2 high-power custom made hybrid modules/drop-in
    Great looking dropins tana! Tempting indeed.
    Input voltage would be a max of 6v right since it looks like you're using he nanjg105c?
    Tana's Avatar
    Mar 2011
    Input voltage is 2.8-4.5V so voltage range of SINGLE LI-ION RECHARGEABLE CELL CAPABLE OF DELIVERING 4.5 AMPS !!!
    Use IMR 17650 in non-bored Surefire body or 18650 in bored body...
    DO NOT USE PRIMARY CELLS IN SERIES WITH THIS MODULE !!!
    omg Tana, I have been procrastinating on sending you my E1e head and now you make me add this to my wish list! Looks good, keep up the good work sir!
    Jun 2013
    Texas
    SEXY!
    Flashaholic Mr.Freeze's Avatar
    Sep 2009
    Pforzheim/Germany
    nice pics, my friend!
    now i can't wait to get mine...
    regards from Germany
    Gunter .::TNT Enlightened::.
    Flashaholic* tech25's Avatar
    Jul 2010
    Near the Big Apple
    Wow! These are nice! I am definitely interested in one!
    Flashaholic* tobrien's Avatar
    Dec 2005
    Georgia Highway 441
    omg these look great!
    Jun 2011
    Quote Originally Posted by Tana View Post
    Don't give new guys wrong ideas here, plaguem...
    Yes, the module will withstand 6 Volts from two CR123 cells....
    Oops forgot to reply. Thanks for the detailed explanation! Great diligence with info as usual. Primary users need to take note. I'm not much of a primary user. Hehe.
    Tana's Avatar
    Mar 2011
    AGAIN, DO NOT USE PRIMARY CELLS WITH THIS MODULE !!!
    USE SINGLE LI-ION RECHARGEABLE CELL !!!
    So, what are the specifications for this drop-in? Voltage, OTF Lumens, ect?
    Thank you.
    ~ Chance
    Never point a flashlight at anything you don't intend to illuminate! Never buy a flashlight you have to make payments on.
    Dec 2005
    Georgia Highway 441
    Quote Originally Posted by Chauncey Gardiner View Post
    Thank you.
    ~ Chance
    I think he stated 6v input max, but definitely don't try that because you'll need 2x CR123s and that's too high of a discharge, but OTF is probably: millions
    Tana's Avatar
    Mar 2011
    Thank you.
    ~ Chance
    Chance,
    Added output specs and voltage range for the module to the first post...
    You can look at these as pretty much similar to any other custom triple module made for single li-ion cell as they usually use same LEDs and drivers... the difference is in type of metal used, PCB metal choice, type of heatsinking (including components of the driver), LED selection, lead thickness/quality and driver setup...
    Dec 2005
    Georgia Highway 441
    Tana, you do such an awesome job. I seriously want to buy everything you offer for my own SF stuff haha
    is the glow powder included in the price?
    edit: have you considered XP-E2 as well?
    These are awesome. If they are as nice as your E Series led modules I will have to buy one.
    Tana's Avatar
    Mar 2011
    Just last night I finished building one of these with XPE2 6500K (cool white) at 3 Amps... Also added that info in the first post...
    ANY (reasonable) LED choice is possible... If I don't have the desired LEDs with me - I could look around and order them...
    Optics is glued in place with clear epoxy (unlike e-series TripLEDs) so I add some GITD for fun, you can opt to go without it... price is the same, with or without GITD...
    Dec 2005
    Georgia Highway 441
    got it, thank you! so is the tripLED P60 comparable in beam characteristics to your E-series tripLED?
    Tana's Avatar
    Mar 2011
    Same components, different package... TripLED P60 driven at 3 Amps is about the same performance/beam to e-series based TripLED mk3 and TripLED P60 driven at 4.5 Amps is what TripLED T1000 offers (triple based on e-series KL4 head)...
    Except for the obvious size of material for heatsinking in both module and host, the difference is that optics in this module, P60 TripLED is glued and it's glued with GITD epoxy plus instead of simpler custom programming I've been doing for months now, I chose to go with pre-programmed driver by professional programmer as a default option (but simpler programming without all that mumbo-jumbo is still available, of course, per personal request)...
    Think you can do one of these mods on a novatac 120t? If so I'll be sending you mine ;-)
    Dec 2005
    Georgia Highway 441
    got it, thank you sir! you do some amazing work!
    Sep 2009
    Pforzheim/Germany
    recieved my p60 tripled today!
    awsome build and it fits perfect in my bored 6p. now waiting for darkness to play with!
    well done tarik, thank you.
    Flashaholic Megatrowned's Avatar
    Jun 2012
    Wisconsin
    Quote Originally Posted by Mr.Freeze View Post
    I see you got a XPE-2 version! Nice! You'll have to post some beamshots if you are able
    Welcome to the Dark Side! Which just also happens to be the Light Side.
    Sep 2009
    Pforzheim/Germany
    ...mostly my camera avoid good beamshots, but i try my best tonight!
    and i try to compare this xpe2 triple against xpg2. hope i find the right camera setting for best results!
    nfetterly's Avatar
    Oct 2008
    Cincinnati area, but lots of travel
    Want one..., will decide on specs & then contact you, Neale
    Sep 2009
    Pforzheim/Germany
    hi guys, here it is:
    it's hard to show the difference of throw at theese pics! the floors in my house or my yard are not long enough for this...
    the xpg triple from oveready is driven at one 18650er with a current of aprox 3.2 amps, so it have a little advantage!
    the tnt tripled with xpe2 emitter have a more concentrated spot and from my own eyes it's brighter than the or triple with the advantage of +0.2 amps. at more than 15 meter the tnt xre2 tripled shot more light to the target! remember, i choose "only" 3amps. on high but the throw is still amazing.
    nfetterly's Avatar
    Oct 2008
    Quote Originally Posted by nfetterly View Post
    XPE-2, 4.5A, neutral tint, green glow
    I think that is it. Please let me know pp details. No rush.
    pp sent.....
    Yesterday Tanas XPG2 Dropin with green GITD arrived.
    Now my fav. C2 host has a proper dropin
    Flashaholic flat-ray's Avatar
    Nov 2005
    Italy
    Really nice!!!
    Tana's Avatar
    Mar 2011
    Quote Originally Posted by Billbo View Post
    SW01 adds a nice balance to Cryos cooling bezel... beautiful setup, Billbo...
    Is that Surefire clip ??? Somehow it seems slightly different from LX2/E2DL-U clip (plus there is a hole on it, not sure on the bended part)... I wonder if SF changed the design a little like they did between E1B and EB1...
    Flashaholic* weklund's Avatar
    Dec 2008
    Orange, California
    Smile Re: TNT P60 TripLED Surefire C2, 6P, Z2 high-power custom made hybrid modules/drop-in
    I will take one P60 w/ Tri Nichia 219B @ 3 amps and Ice Blue GITD. What a awesome drop-in.
    ....."Happy Landings".....
