Sold/Expired Lumen Craft gat Light
SuPpAvIlLiN
Woods
Hi guys. I am selling my Lumen Craft Gat light V-3. Titanium and carbon fiber.Like new in box. asking No Longer available shipping CONUS. Higher shipping for international buyers.
Light Source
Premium bin LED (SSC P4 bin USX01) selected for brightness and color tint (pure white) rated at 240+ Lumen by manufacturer
Operating Life LED
100,000h (11 years)
Optics
Circular Narrow Beam Optic with half angle divergence of only 6 degrees.
Brightness Regulation
Proprietary regulation circuitry maintains constant light level as battery voltage drops.
Dimensions/Weight
3.5'' x 1.125'' Weight (with battery): ~100gr (3.38oz)
Battery
3V CR123 Primary Lithium. To replace battery simply unscrew the knob in the back.
Push button switch with momentary functionality and a rotary knob to adjust brightness.
Low Battery Indication
When set to full brightness flashlight maintains constant brightness level. When full brightness can't be maintained anymore (battery low) brightness level drops. After a while the light will begin to strobe – indicating that battery needs to be replaced. After a while the strobe stops and the light can still be used at a very low brightness level for about an hour – until the 123 battery is fully depleted.
Multi Brightness Levels:
Unlimited regulated brightness levels are available by turning the knob in the back allowing either maximum brightness or maximum runtime or any setting in between.
Water Sealing:
The light is designed and built to be fully submersible – however individual units have not been tested by submersion. As a result the official rating is "water resistant".
Materials:
The metal parts of this light are made of 6AL-4V (grade 5) Titanium – an aerospace alloy many times stronger than the more commonly used grade 2 titanium found in jewelry. The thread of the back knob is sintered bronze, a self lubricating alloy to prevent galling (thread locking) often found with titanium threads. The battery tube is made of light weight carbon fiber composites with a ground & varnished 4x4 twill weave cosmetic layer.
Gold plated contacts for minimum electrical resistance and corrosion protection.
Machining
High precision components with <0.0005'' (0.01mm) tolerance. Machining surface finish of less than 4 Ra
Assembly:
Each GatLight is carefully hand assembled by skilled aerospace technicians.
Number of Parts:
Each GatLight consists of over 80 parts. 42 parts are custom machined metal parts. The 24 screws are custom made on high end Swiss screw machines, since stock screws did not meet the quality demands for this light.
Serial Numbers:
Each GatLight contains a unique laser marked serial number showcasing the limited production of this product. Serial numbers produced: 1-200
Accessories
Each GatLight comes with an attractive solid wood display box with a bronzed Lumencraft logo.
stingray3
USA
Is this still for sale, sold, or withdrawn? I am interested if still for sale.
