Jetbeam
Results 1 to 11 of 11
Thread: Samsung ICR18650-26H 2600mAh (Pink)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Samsung ICR18650-26H 2600mAh (Pink)
    Official specifications:
    • Nominal Capacity: 2600mAh (0.2C, 2.75V discharge)
    • Minimum Capacity: 2550mAh(0.2C, 2.75V discharge)
    • Charging Voltage: 4.2 0.05 V
    • Nominal Voltage: 3.63V
    • Charging Method: CC-CV (constant voltage with limited current)
    • Charging Current: Standard charge: 1300mA, Rapid charge : 2600mA
    • Charging Time: Standard charge: 3hours, Rapid charge: 2.5hours
    • Max. Charge Current: 2600mA (ambient temperature 25)
    • Max. Discharge Current: 5200mA (ambient temperature 25)
    • Discharge Cut-off Voltage: 2.75V
    • Cell Weight: 47.0g max
    • Cell Dimension: Height : 65.00mm max, Diameter : 18.40mm max
    • Operating Temperature: Charge : 0 to 45C, Discharge: -20 to 60C
    • Storage Temperature: 1 year : -20~25C, 3 months : -20~45C, 1 month : -20~60C
    A standard 2600mAh cell from Samsung.
    Very nice matching of the two batteries and capacity is nearly independent of load. This battery has slightly higher capacity than the 26F model, but lower voltage.
    Conclusion
    This is a very good cell for a standard 2600mAh cell.
    Remember that the cell is unprotected this means it will have higher voltage at "high" load than protected batteries.
    Notes and links
    The batteries was supplied by Akkuteile.de for review.
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    Compare to 18650 and other batteries
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    *Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    Default Re: Samsung ICR18650-26H 2600mAh (Pink)
    Good cell manufacturers make good cells.
    Stay with the known players and be happy.
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
    Flashaholic* Overclocker's Avatar
    Aug 2005
    Philippines
    thanks for the review! very similar curve to the NCR18650B, with the panasonic only showing an advantage at the lower voltages, your single-cell flashlight wouldn't give a damn
    i picked up 100+ for a project before HKJ reviewed it so i'm glad i made the right choice! if only i could decipher the date code on these...
    Jun 2010
    South Korea
    Excellent review. HKJ!
    Your review shows fairly well what the difference between the 26F and 26H is. Thank you.
    Hi i am new on the sight and new to fancy fashlights and batteries i just got a new nitecore p12 i have a samsung 18650 26h pink and i was wondering if i can use this battery in my new p12 it uses one 18650 and i have a nitecore d2 and will it be fine to charge such a battery and what safety do i need when charging thanks your time is kindly appriciated
    Feb 2012
    Miami, Florida
    Quote Originally Posted by No use for a name View Post
    Welcome to the club.
    Do your Samsung 26h cells have an added protection circuit, or do they look exactly like the pictured ones do?
    You should be able to use the Samsung 26h in your P12 and you should be able to charge your Samsung 26h cells up in your NiteCore D2 charger.
    The only issue might be that if your cells have a protection circuit added by a second hand battery rebrander, they might be too long to fit any given light, but you'll know that soon enough.
    Some people like to charge outside, but with a good charger and cells, I don't worry about doing that. Finally, others place the charger in something like a metal stock pot.
    Enjoy.
    Chris
    Hi thanks chris for your time the samsung is an unprotected cell like in the pic shown
    I got 4 of these batteries last night, seem to be legit, a solid deal, IMO, cost me 13,51EUR with shipping.
    What I was wondering are the faint markings on them, I think the markings are on the metal battery case itself...
    What do they exactly mean?
    [IMG]<a href="http://tinypic.com?ref=sptzl0" target="_blank"><img src="http://i60.tinypic.com/sptzl0.jpg" border="0" alt="Image and video hosting by TinyPic"></a>[/IMG]
    I got a 26H from a local dealer.
    Is it normal that the positive tip does not look centralized? The problem is not the tip, it's the wrapping over the top that is misaligned.
    And the printed markings on the wrapper are wearing off. I must have rubbed my fingers over them after charging and the battery was warm.
    Flashaholic* kosPap's Avatar
    Mar 2007
    Naoussa Greece
    Quote Originally Posted by Dusanissimus View Post
    since I have re-wraped mine in clear shrink tubing, they read:
    G077
    291D4
    but they do not look like the product codes that one can find on the pink wrapper
    http://www.tomobattery.com/blog/sams...ure-date-code/
