Acebeam
Page 11 of 170 FirstFirst ... 4567891011121314151617182161111 ... LastLast
Results 301 to 330 of 5086
Thread: SkyRC — IFA 2014 — MC3000 charger-analyzer
  1. #301
    Default Re: SkyRC — IFA 2014 — MC3000 charger-analyzer
    Oh my god!!
    I love this charger even more!
    I am moooooore anxious
    I like the parameters. Seems ok..
  2. #302
    Oh my god!!
  3. #303
    Feb 2009
    Florida, AKA God's Waiting Room
    Since you said it TWICE, I for one, believe you:-)
    -Chuck
  4. #304
    23 Input limit min volts: {10.0|10.1|…|11.9|12.0}V min volts: {10.0|10.1|…|10.9|11.0}V
    If this unit is to have car-charging facility, might as well change the Input limit to range from 10vdc to 16vdc?
  5. #305
    Hola fran82, great to see your interest, you re finally back a regular visitor on the flashlight forums!
    tatasal what s the DC voltage supply output range of the car? The General Setup View (GSV) has an item which says
    Input: 14.8V>11.0V
    filling exactly the permissible 18chars per line in standard font.
    Tbh i dont know what it means haha. The "14.8V" seems to be the measured voltage of the power supply unit, one cannot change this value. The "11.0V" is the value which the user can edit and set to anything between 10.0 and 12.0V. I am guessing that this is the minimum supply voltage which the device accepts for operation. If you set it to 12V, it would mean that you dont want your supply voltage to drop below 12.0V,i.e. that you prefer a rather stable voltage between 12V and the max allowable voltage (which is 18V afaik). The label for the PSU plug says "DC INPUT 11-18V". GSV indicates that the lowest acceptable supply is 10.0V, i need to reconfirm it with the maker (EDIT: 2015-05-31, status: unconfirmed). If that is true, then your 10-16vdc falls into the 10-18vdc range, so no problem .. as long as the car can deliver the required amperage.
    The dimensions of the charger arent very portable nor is the weight. For spacious cars no big deal
  6. #306
    Yes! It was a confusion..
    It is MIN input voltage between 10 and 12.
    So the charger will accept between 10 and 18 volt.
    Great!!
  7. #307
    I need this charger in my life, dedicated shrine in construction.
  8. #308
    Is it too soon to be talking about price range for this charger?
    At this point after all thats been said about the MC3000 price is the only factor that decides if I will be able to get one or not.
  9. #309
    Someone said.. Between 60 and 100 USD....
  10. #310
    Flashaholic _UPz's Avatar
    Oct 2012
    Barcelona
    Quote Originally Posted by fran82 View Post
    I am pretty sure this charger will be really worth every penny paid for it.
  11. #311
    looks like they got the new pcb for finals!
    the .. wth
  12. #312
    What can be read at the bottom right?
    "HI KREISLER"??
    Wtf???
    They have good humour sense!
  13. #313
    Oct 2012
    Barcelona
    lol, HIKRSL
  14. #314
    Unenlightened virus_59's Avatar
    Mar 2014
    Amsterdam
    I like this charger and I would buy it.
    But I want to replace them all my chargers:
    - NiMh
    - Li-Ion
    - USB
    I would like to have more usb ports, at least 2 (with automatic selection of coding).
    Also, I need information about USB-out on display: voltage, current, mAh/mWh.
    Ideally, I would very much like to have support for USB 3.1 and all the charge profiles (at least up to 12 volts):
    - 5 volts and 1.5 / 2.0 / 3.0 Amps
    - 12 volts and 1.5 / 3.0 / 5.0 Amps
  15. #315
    Quote Originally Posted by virus_59 View Post
    - NiMh
    - Li-Ion
    - USB
    Wow, lurking for 14 months before posting. Not sure what you want to use something like this for USB support.
  16. #316
    Does it still charge D batteries, and will it discharge 18650 to storage voltage?
  17. #317
    i will agree with Dubois, the device is mainly a charger-discharger, not a USB meter. my favorite USB meter is the inexpensive KCX-017, so people can just use such a gadget as accessory. the USB power output is 2.1A / 5V, and that`s about it, no serious plans to expand this already neat offer afaik.
    yes it still charges/discharges D batteries, without adapter.
    yes it will discharge/charge 18650 to storage voltage. you can set for example "3.75V" as storage voltage, insert an empty or full 18650 in the slot, start the program, and when the program is finished, you remove the battery and can measure 3.750V, stable, on your multimeter. the storage operation mode employs CV-phase and inverse CV-phase, called Discharge Reduce, to reach the storage voltage as closely as possible. termination current can be set to 0.01A or lower.
  18. #318
    Feb 2009
    To begin with, will just the Hobby Shops have this, or do you think it will come out of the gate at the Usual Flashlight Suspects also? - US Dealers and the Big Chinese houses?
    I have a charger/s now, but this I see as a Must Have!
    Thanks,
    -Chuck
  19. #319
    Mar 2014
    Amsterdam
    Quote Originally Posted by Dubois View Post
    ... lurking for 14 months before posting ...
    Just read ...
    Quote Originally Posted by kreisl View Post
    Pity. But I don't not need a USB-meter, I just a very comfortable to see (on the ammeter) that charging is complete.
    I mean that now I have three chargers (each of which takes its socket with a switch, it's more like a power plant control panel ), and would like to have everything in one.
    Maybe in the future
  20. #320
    Chuck good question.. I believe that they don`t know what to do with this atypical product in their RC Hobby catalog, who of the regular RC hobby folks would be interested in it, those laugh about our single cells
    Maybe a flashlight distributor would be a more appropriate point of departure
  21. #321
    Feb 2009
    No doubt that there are steps being made on both sides Flashlight Distributors and SkyRC as we speak -Well, Here's to Hoping!
    Thank you,
    -Chuck
  22. #322
    It would be nice for us Europeans to see this charger available from the better Chinese dealers (like HK Equipment).
  23. #323
    Unenlightened
    Jun 2015
    Europe
    Been lurking for a while in this thread as I am interested too in the MC3000. Hope it is released soon so that we can read some reviews
  24. #324
    Flashaholic* psychbeat's Avatar
    Nov 2009
    SF norcal
    Just to confirm-
    There is a 4.35v charging option on the final update ya?
    I'm hoping to justify buying one of these by getting a few D1s or something so I'll actually "need" it rather than want it hahah
  25. #325
    Quote Originally Posted by psychbeat View Post
    Just to confirm-
    That is a brilliant idea - I will buy some 4.35v cells, then explain to my wife that I made a mistake, and need a new charger to get the full use out of them. I love it.
  26. #326
    Feb 2009
    4.35v - Yes!
    And, please SkyRC, make it where I can use it without taking the charger apart every time, going from 3.6 - 4.2 - 4.35. - Sound familiar? :-)
    I have a Nitecore D-4, and use the LiFePO4 setting (3.6v) to charge to Storage level for Li-Ion - Very handy.
    Please tell me when and where I can send the money! - SOON, I hope:-)
    Thanks,
    -Chuck
  27. #327
    Just to confirm-
    http://www.candlepowerforums.com/vb/...=1#post4500568
    There was always that option from this post in the thread from what I have seen.
  28. #328
    Just to confirm-
    34 LiIo4.35 CHARGE target voltage {4.10|4.11|…|4.39|4.40}V N/A N/A 4.35V]
    Erh.
    Confirmed
    Kreisl now in Guangzhou
  29. #329
    Feb 2009
    Are you going to be bringing one home with you?
    Thanks,
    -Chuck
  30. #330
    Most definitely not.
    I passed through Shenzhen, am now in the centre of Hongkong, and i got nothing in my bags but some Eagletacs, Eneloops and a cheap new 4bay charger yet not by Skyrc
    I did contact the company and they plan to send me a mass produced review unit anytime "soon"
