Gearbest
Page 158 of 169 FirstFirst ... 58108148151152153154155156157158159160161162163164165168 ... LastLast
Results 4,711 to 4,740 of 5061
Thread: SkyRC — IFA 2014 — MC3000 charger-analyzer
  1. #4711
    Default Re: 2nd gen dreamcharger presented on IFA Berlin 2014…
    The SW really is poorly written, under 7 with increased DPI settings I got half of the settings window overflow where I can not see it cause the window size is static and can not be made larger (ehm). Gonna have to use it with some of the XP machines anyway for now. I've also learned from the distributor that I will need single computer for each charger as the SW can not handle more chargers simultanneously, that's not much advanced either. Well I don't neccessarily NEED the SW, can as well read the values from the display, it just appears to be easier to maintain.
    And than they wrote me some talk about how this is for modelers so nobody will buy charger for 8+ cells which I told them to inquire from SkyRC. Well since there is no such advanced device for more than 4 cells, I would say somebody will bloody buy that as there would be no other option. But this is like barking on a tree…
  2. #4712
    To kreisl :
    On page 1, we can find this bug :
    bug: NiMH "D>C, N=1" should report discharged capacity as "Cycle1" in SOV (UNCONFIRMED)
    I think i can give you some explanations :
    If the charge processus ends in a normal way ( delta peak for exemple) then the discharged capacity is reported as Cycle1.
    But, if the charge ends in an abnormal way (for me, capacity cut), then discharged capacity is not reported at all.
    The discharged capacity should be reported all the time.
  3. #4713
    Default Re: SkyRC — IFA 2014 — MC3000 charger-analyzer
    Quote Originally Posted by Dr. Mario View Post
    LTO cells do exist, but is expensive, and hard to find. At least for now, as was the case with Li : FePO4 cells back in mid-2000s. I can wait though, as MC3000 is software upgradeable, as far as I know.
    Are you still waiting?
    pretty epic
  4. #4714
    Default Re: SkyRC Β— IFA 2014 Β— MC3000 charger-analyzer
    Quote Originally Posted by Mr.Ampere View Post
    As a first contribution, i Will share my experience with DEX logging and configuration, not so easy as one could think...
    So, when I first installed DEX, some values were reported wrong (for example, the battery temperature was 270 instead of
    27,0°C). Looking around in DEX, I found the "Device properties editor" window, and specifically the "Outlet-channel/Configuration" tab.
    For example , choose the "slot1" tab, "Battery temperature" sub-tab :
    - right clic on the "Statistics" sub-sub-tab, "Add Property Type" and the "Factor"
    - you can then enter a value (0.1 in my case) and save all this...(SAVE button)
    BUT, if you try to modify this for another slot, save it, and look at the first slot again, the parameter previously saved is missing ! A bug in the saving process I guess...
    So, what you can do is editing the file in an appropriate editor, such as NOTEPAD++ (freeware) :
    1. go to C:\Users\<yourname>\AppData\Roaming\DataExplorer\D evices
    2. do a backup of "MC3000.xml" and "MC3000-Set.xml"
    3. do a copy of "MC3000.xml" => "MC3000-MYSETTINGS.xml"
    4. edith the "MC3000-MYSETTINGS.xml" file with NOTEPAD++
    5. the xml file is self-explanatory :
    in the "Device" section, modify the name of the device :
    <name implementation="gde.device.skyrc.MC3000">MC3000-mysettings</name>
    in the "Channel" section, adjust your parameters, for example for the battery temperature :
    <Measurement>
    <name>BatteryTemperature</name>
    <symbol>Tb</symbol>
    <unit>°C</unit>
    <active>true</active>
    <statistics min="true" max="true" avg="false" sigma="false"/>
    <property name="factor" value="0.1" type="Double" description="Correction for temperature slot1"/>
    </Measurement>
    do the same for the 3 other slots, and maybe for other values you want to correct/adjust
    6. save the file , and add the "read only" property to the file (sometimes, DEX try to modify the file even if you don't access the "Device properties editor" window).
    7. then , in DEX, add your new configuration file with the "Device selection dialog" window...
  5. #4715
    Nov 2011
    north carolina
    is the max discharge still 1 amp for this unit, with latest firmware for lion batteries ?
  6. #4716
    Feb 2005
    Using "Simple" mode I set it up to do a charge under "Eneloop AA" to charge four Eneloop AA's and all were alarmingly warm upon completion of the charge cycle. I thought heat was the enemy of NIMH cells and I also thought this charger was programmed to take the very best care of my batteries. What gives?
  7. #4717
    Nice try
    I should try again too
    "Hello S.W. 17-05-31"
  8. #4718
    Flashaholic tjh's Avatar
    Sep 2013
    Napier, New Zealand
    Quote Originally Posted by HighLight View Post
    Charging with -dv/dt will warm the batteries. If you want super cool cells that aren't fully charged, terminate on 1.48v.
    The charger is designed to be as flexible as possible... Not to baby your cells. Most people agree that a slight warming caused by -dv/dt isn't a problem long term anyway, but if you're paranoid about your cells this charger gives the power to trickle them along as cool as a cucumber if you want.
  9. #4719
    Quote Originally Posted by kreisl View Post
    @HighLight, sorry i misread your post. I thought that your were talking about the "Dummy" mode. So today i tested the Dummy UI Mode. The Eneloop AA's stayed cool as **** for the entire time. No wonder, because since FW1.10 or so the charger uses the MH-C9000 algorithm to terminate the Eneloop charging which is a very conservative way of charging. Hence my advice, if you're worried about cell temperature and don't want to fiddle with settings, you can use MH-C9000 or the MC3000 Dummy mode.
  10. #4720
    What you think about these 1.5v Li-ion AA rechargeable batteries? I guess this dreamcharger can't handle those.
    https://www.amazon.com/KENTLI-3000mW...dp/B01H0H6K2C/
  11. #4721
    Sep 2013
    Napier, New Zealand
    edit: I'm 100% wrong, see below.
  12. #4722
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by tjh View Post
    Not currently, but if they became really popular a simple firmware update and they would be supported.
    No, they require a special designed connection in the charger.
    Actual charging algorithm is normal LiIon.
    I have taken a look at the older generation: http://lygte-info.dk/review/batterie...e%29%20UK.html
    My website with battery, charger, usb reviews, comparisons & information: lygte-info.
    Latest addition is multimeter reviews
  13. #4723
    Sep 2013
    Napier, New Zealand
    Thank you, I stand 100% corrected and feel suitably silly
  14. #4724
    maybe this is the official website for end consumer? -> http://www.unbatteries.com/
    i am guessing that one could build a DIY adapter for this exotic battery in mc3k slot, similar to the Kentli charger's positive terminal:
    (photo credit HKJ)
    Today i am testing FW1.14beta with DEXbeta, the LTO got implemented just fine in either software, debugging now. Since i have no real LTO battery, i made a substitute sufficient for the sake of testing the codes lol :
    ( project history: pic1, pic2, pic3, pic4, pic5, pic6 )
    2xAA is about in the voltage range of LTO. Not my idea, so plz don't hit me
  15. #4725
    If new firmware is in the works, how about they make the program shortcuts(currently UP+SNB) usable while theyre at it.
    Big issue with using the shortcuts, is that if you already have 1 battery charging you cant use them because pressing up or down takes you to DDV(voltage + temp graphs).
    Either priority can be used, say if any slot in READY state then pressing UP or DOWN doesnt activate DDV, or make DDV a longpress command on UP or DOWN.
    Also at the moment you can only program 4 shortcuts, make that 8 by adding the DOWN+SNB.Easier to make full use of the function if youre using more than 1 chemistry. That DOWN+SNB combination sitting unused for very long, time to get it in the game
  16. #4726
    I thought the same, thanks for pointing that out.
    Great to see huge progress on LTO chem support implementing!
  17. #4727
    Another idea I'm thinking about is related to calibration and voltage measurement.
    Currently only one value both for voltage and current is used for calibration and so the charger simply scales the readouts according to the computed calibration factors.
    But to take care of voltage offset issues, if feasible, the charger could enable an advanced voltage calibration to compute both an offset and a scaling factor to improve voltage measurement. Obviously the user will have to use two different cells to be able to calibrate at 2 corresponding voltages (and not too close one to the other to have a better offset estimation).
    What do you think about this idea?
  18. #4728
    Quote Originally Posted by DeJaVu View Post
    If new firmware is in the works, how about they make the program shortcuts(currently UP+SNB) usable while theyre at it. Big issue with using the shortcuts, is that if you already have 1 battery charging you cant use them because pressing up or down takes you to DDV(voltage + temp graphs). Either priority can be used, say if any slot in READY state then pressing UP or DOWN doesnt activate DDV, or make DDV a longpress command on UP or DOWN. Also at the moment you can only program 4 shortcuts, make that 8 by adding the DOWN+SNB.Easier to make full use of the function if youre using more than 1 chemistry. That DOWN+SNB combination sitting unused for very long, time to get it in the game
    Hello DeJaVu, the <UP+SNB> works also when a slot is charging 1 battery. For example [11] be assigned to <UP+SNB1> and the charger status be:
    #1 [01] busy; #2 [02] empty; #3 [03] ready; #4 [01] empty.
    Now hit the <UP+SNB#1>-keys at the very same time. For this, I recommend using <index+middle>-fingers of your right hand if you're a righty; this would be 1 double note with fingering (2 3). Hit crisply, don't press. Similar to wrist staccato. If the two keys don't get registered at the vely same moment, then yes you will end up in DDV . Today I wanted to shoot a short video demonstrating my staccato of the double note but these days i am too busy watching roland garros sorry . Anywho i've tested it and the new charger status becomes:
    #1 [01] busy; #2 [11] empty; #3 [11] ready; #4 [11] empty.
    In fact, #1 does really not get overwritten. So when you long-press <STOP> now, the status becomes:
    #1 [01] ready; #2 [11] empty; #3 [11] ready; #4 [11] empty.
    This behavior is correct and as intended by 🐿️
    ( If you find a written description of <UP+SNB> which differs from this example, then you found something wrong 🤐 )
    (( The reason why there is little time tolerance for the double key pressing is of technical nature and can't be helped. Just saying, these common switches are not designed to be pressed at the same time. Think of the rubber buttons on any handheld DMM, and try to press two of them at the same time as normal operation; so DMM designers don't program double key presses as normal operations of the UI. Switches/keys for this purpose do exist though 🤑, they are made in gemani ))
    8? 😶
    OIC
    No promises when we get your 8 but i am seconding it. Good call!
    If anyone has another suitable suggestion for DOWN+SNB, please let us know thanks appreciated! Otherwise we'll do the 8 np. 😝
  19. #4729
    God damnit, it was working all this time.........
    When there is no busy slots, then you can press UP+SNB sequentially and it works.Because of that it seemed to me that it isnt working when there are busy slots, as sequential pressing would always land me in DDV.
    Im glad to find out after all this time that it actually works , but still it would be nice from usability perspective, to add slight delay to DDV, like 1second or so.
    With the current configuration you can still miss-click and dont get the desired effect which is somewhat frustrating.
    DDV longpress = happy program shortcut users :P
    8? 😶
    OIC
    Yeah it would be nice addition.Personally i would use 4 for Li-Ion and 4 for Ni-Mh as those are the most common chemistries i use, and at the moment 4 are just not enough to cover most popular battery sizes.Im sure other people would tailor it to their specific needs.
  20. #4730
    i've added your 2 suggestions to de list. you might see them as improvements but imho the longpress-for-DDV is a toss. by now i am firmly used to shortclick-for-DDV (and i certainly enjoy hitting the charger) as detailed in all the documentation (MANUAL, CHEAT SHEET). I'd rather agree with the 8 memories but this would entail changes in both the manual and cheat sheet too. from what i can tell, from now on it will take longer and longer until we see such minor fine-tunings finally accepted and realized. the folks prefer to wait and collect more suggestions or more substantial ones, before they finally agree that altogether the changes are warranted in 1 batch job.
    well, your fine-tune suggestions are on the list, and they will be seriously considered and eventually implemented.
    at some point 😉
    your attention to detail is appreciated, thanks so much!!
  21. #4731
    I'd prefer measurement and charge profiles improvements (if possible) rather than changes limited to the user interface...
    Anyway the simple fact that the charger development is still in progress makes me really happy.
  22. #4732
    well, we the community are developing.
    they only do the implementation
    that's how i sees it
  23. #4733
    Flashaholic* TinderBox (UK)'s Avatar
    Jan 2006
    England, United Kingdom
    Kreisl
    A guy on BLT has a problem with his MC3000, He says the battery sliders are hard to move, Other members are sugesting lubricating them, I recommended to checked with you first.
    http://budgetlightforum.com/node/54703
    John.
    "Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life." - Terry Pratchett.
  24. #4734
    Thanks John. The slider slides on top of the rail. On top. So there can't be anything holding the slider back from its movement and the sliding movement should feel natural and unimpeded. I could think of 3 tings:
    1) the spring gets caught somewhere inside, maybe at the edge of the PCB. This would create a scratchy sound.
    2) the tip of the spring is not seated in the middle of the slit of the rail. This would create a scratchy sound too.
    3) the bottom edges of the slider are not rounded off, the burr(s) scratch along the rail. This would scratch up the rail.
    While the production line worker found the sliding behavior of a particular unit within the acceptable tolerance band, QC passed!, a very critical end consumer might prefer natural unimpeded sliding as on my sample.
    I am a critical end consumer, so i checked 1) 2) 3) to pass my own QC. Personally i don't recommend the use of Deoxit Gold or other grease on the rails. In the end grease only catches dust/smoke/debris and things get dirtier i guess.
    hope this helpz
  25. #4735
    Quote Originally Posted by cpa View Post
    I've got mine already. It is a chinese one, but I am very happy with it... The temp is now about 35~38ΊC at idle (7ΊC less than before), and 60ΊC compiling, for example. It's a very good result.
    mine idles around 40~44ΊC and reaches 50~61ΊC depending on the external setup. i am so pleased with it 😚 that i did a quick review:
    Review: Raspberry Pi aluminum case assembly, mod & thermal test
  26. #4736
    Quote Originally Posted by ArmaBene View Post
    Completely ignored??
  27. #4737
    Mar 2013
    Portugal
    what are the differences between the MC3000 and the NC2600?
  28. #4738
    Flashaholic* ChibiM's Avatar
    Aug 2009
    Holland/Tokyo
    NC2600 is the Lithium-ion-less version. Should be for nimh and nicd only.
    Eneloop info thread 2005-2017 @CPF
  29. #4739
    sorry, i couldn't understand the need for two point calibration.
    someone published a video showing how offset the voltage (and amperage) is, what do you think, further calibration needed?
    https://www.youtube.com/watch?v=tjSQAQIQlv8
  30. #4740
    Default Re: SkyRC — IFA 2014 / CES 2016 — MC3000 charger-analyzer
    Quick question regarding semantics. In terms of "calibration" using a reference source, isn't that completely different to "adjustment"? In my mind, calibration is about keeping track of an instrument's drift over time, to ensure a reliable confidence level in its readout. Once adjusted, with new settings, there's really no way of knowing the accuracy one week further on, sort of back to square one when the history is lost?
    Just thinking out loud, no expert in the matter. :-)
