SunwayLED
Page 171 of 172 FirstFirst ... 71121161164165166167168169170171172 LastLast
Results 5,101 to 5,130 of 5134
Thread: SkyRC — IFA 2014 — MC3000 charger-analyzer
  1. #5101
    Mar 2017
    Long Island NY
    Default Re: SkyRC — IFA 2014 / CES 2016 — MC3000 charger-analyzer
    Quote Originally Posted by Wrongway View Post
    I still have 1.13 firmware. I don't have any LTO cells so is it worth me upgrading to 1.14? As I can't find a changes list I don't know if anything else was added/changed/repaired.
    Post #6 in this thread has a list of the changes in FW 1.14.
    Frank
  2. #5102
    May 2017
    Cumbria, UK
    Quote Originally Posted by fmc1 View Post
    Frank
    Ahh thanks. I was looking on the SkyRC site for a list.
  3. #5103
    Unenlightened
    Jan 2018
    Russia, St. Petersburg....
    DDV not present in FW1.14.
  4. #5104
    Quote Originally Posted by inetchik View Post
    I wish there was a changelog on the first page of this thread... :P
  5. #5105
    Oct 2006
    Maui, Hawaii
    Wow. tl;dr
    From what I could comprehend after reading some posts and searching in this thread I decided to buy a SkyRC MC3000 off eBay. It came in fast and I had it running the second night I had it. Much more options to charge and condition my batteries. I found the simplistic recording app from SkyRC not well developed and I didn't use it. I was able to update the firmware quite easily. I am finally figuring how to set up the different charging programs for the different cells I have on hand which isn't much. I just bought a Uniden BCD436HP scanner so I stocked up on some Eneloop Pro AA cells. i already have a bunch of 18650 Li-ion cells of varying capacities and age so I'm checking on how much capacity they still have after all these years.
    I have a MAHA MH-c808m that I sent back for repair and that worked out well for 6 years until it would not charge on three of the charging bays. I also have a Pila IBC charger that worked out fine after all these years charging my 18650 cells. But now I want to really understand how well my cells are doing and to keep them in top shape. I also bought a Xtar Dragon VP4 prior to the SkyRC MC3000 as I liked the different options it had. So I will be set up well enough into the future with all these chargers on hand to keep my cells running well. Thanks for all the info that I was able to read on this huge thread. It gave me a better understanding on what I should be doing and keeping my eye on. Aloha and mahalo!
  6. #5106
    Sep 2016
    Germany
    • (k#90) in TOV, not clicking <UP/DOWN> but long-pressing the button should invoke DDV (CONFIRMED, FIXED, TESTED)
    Why has it been changed?
  7. #5107
    Can someone post a link to the latest version of this charger please?
  8. #5108
    Quote Originally Posted by STIXXXXX View Post
    Because when using the program shortcuts UP/Down + SNB , you had a big chance ending in DDV instead, if the timing of pressing both buttons wasnt perfectly synchronized.
  9. #5109
    Unenlightened
    Jul 2018
    Default Re: SkyRC — IFA 2014 — MC3000 charger-analyzer
    Quote Originally Posted by luciof View Post
    Update: after replacing the MCP3424 chip, the "MCP3424-1 Err" Warning has gone (I guess a "MCP3424-2 Err" would pop out when the other chip fails).
    After a painful reassembly and a quick check, everything works fine.
    I'll do a more thorough test as soon as I find the time.
    Just wondering, I don't suppose there are any further updates to this problem?
    My unit has been working fine getting minimal use, admittedly connected to a bunch of 12V batteries powered by a solar panel (via a regulator).
    Despite the input voltage range of the charger saying 11-18V, and my input never being below 12V (there's a car battery and 8 x 7.2Ah 12V SLA batteries connected to an 80W solar panel only running this charger), it's quite common to get a "Low Voltage Warning" when I connect the power to the MC3000 - but it goes away and operates - er - has operated - fine when I just hit the Return key.
    I left a single NIMH AA battery charging in slot 1 (0.7A) - it finished charging yesterday but I left it in there - and this morning I come to get it and see the MCP3424-1 Err message.
    I don't know of any damage to the spring-holding posts, and I've not opened the case at all (yet).
    I guess I'll have to try to replace the MCP3424 chip - but just thought I should check for any updates on the topic, and share my experience.
  10. #5110
    Sep 2016
    Germany
    Quote Originally Posted by DeJaVu View Post
    Ah, thanks. I never knew you could use the shortcuts, when a slot is already charging. Makes sense then
  11. #5111
    Hello,
    Do you know if I have to redo my calibration procedure after firmware update ?
    Thank you
  12. #5112
    Unenlightened wheniwake's Avatar
    Jul 2010
    Scotland, UK
    So.... My plug was still on and I plugged in my charger. Little blue spark and nothing from the charger! Power brick still shows red LED but charger is dead. Any ideas?
    Tested the brick with a multi, still putting out 15V DC.
  13. #5113
    Sep 2016
    Germany
    Quote Originally Posted by Dubalgan View Post
    Hello,
    Thank you
    Hi, no need to redo calibration.
  14. #5114
    Hello, which settings would you advice for standard AA eneloops? After reading a bit through the forums, I configured for Refresh cycle (via BT):
    Capacity: off
    Charge current: 1A
    Discharge current: 0,4A
    Charge cut current: 0,1A
    Discharge cut current: 0,4A
    Charge cut voltage: 1,65V
    Discharge cut voltage: 1V
    Cut temp: 45C
    Cut time: off
    Rest time: 15m
    Restart voltage: OFF
    Delta V: 3mV
    Tricke C: OFF
    Should I for example set the Capacity, Cut time (as a safety measure). Are the other values OK?
    Thanks
    Peter
  15. #5115
    Hi everyone!
    I am fairly new to the LiIon batteries and have recently acquired a SkyRC MC3000 charger. Which I have found to be exceptional.
    I have read almost through the whole thread, and did some research online on the charger, features, data logging, connection and so forth.
    I have played around with it doing some datalogging on my Window Computer with DEX, and have initiated the process of setting up a Raspi 2 B for logging data without the need for an external computer. I have done extensive searching to put the required pieces of information together on how to set up the whole system.
    I would like to have the Pi to work as an external datalogging without the need of user intervention for later data retrieval.
    So far, I have not found any detailed instructions on how to accomplish what I would like to achieve. These are the main things I would like the system to perform:
    • Upon plugging the Raspberry, it should automatically start DEX (for which there are some instructions).
    • It should also start automatically data retrieval.
    • It should automatically save datalogs (continuously or every xx time) a .CSV (preferred) or .OSD to a specified folder.
    • It should have a shutdown button to stop logging, close DEX and shutdown Raspbian (this could be accomplished by some scripting and digital inputs).
    • It could be a great addition to have DEX incrementally change folder or filename of output upon the push of a button (to log data from a different set of batteries and keep track of them.)
    If you could launch DEX using command line, specifying device and output that could help.
    Perhaps there is a better alternative which is to dump raw data coming from the charger into a CSV file (Python?).
    I will really appreciate if you could share your updated implementations. Please feel free to move this post into a new thread if you feel like so.
    Thank you!
    Regards
  16. #5116
    Quote Originally Posted by Gaudi View Post
    Hi everyone!
    I was also thinking about combining a raspberry pi with a skyrc mc3000 to do some nice (low power) data logging. Please post about your progress (and results)!
  17. #5117
    Quote Originally Posted by pse View Post
    Capacity: off
    Charge current: 1A
    Cut temp: 45C
    Cut time: off
    Rest time: 15m
    Delta V: 3mV
    Tricke C: OFF
    Thanks
    Peter
    AACycler did some interesting tests that might help you determine the optimal settings.
    For charge current: http://aacycler.com/post/high-current-vs-low-current/
    For charge cut current voltage: http://aacycler.com/post/discharge-cut-off-comparison/
    For Delta V: http://aacycler.com/post/charge-algorithm-comparison/
    For LSD (Low self discharge) cells HKJ prefers no trickle charge.
    To prevent overcharge I would set a maximum capacity and cut time.
    Edit: Also some information from HKJ's review of this device:
    NiMH
    Be careful with charge current, using anything below 0.3C will probably miss termination on AA/AAA cells. I mostly uses around 0.5C.
    To keep the cells safe if the terminations is missed use a capacity limit between 130% and 150% of the cells capacity and a timer cutoff calculated as capacity/current*1.4, i.e. for a 2000mA cell at 1A it is 2000/1000*1.4 -> 2.8 hours -> 2 hours 48 minutes.
    FOr NiMH the -dv/dt setting must be as low as possible, I used 3mV for my test, but a lower value might be even better. Too low value will not damage the cell, but might give early termination.
    LSD cells do not need any trickle charge, for other cells a 10mA trickle charge can be used, but it not really needed either (Some manufactures recommend a time limited trickle charge after a -dv/dt charge).
    Official termination voltage for NiMH when discharging to measure capacity is 1 volt, but there is no problem going lower (like 0.8 volt).
    With NiMH the cycle mode can be used to refresh cells that has been unused for some times.
    break_in is the official way to measure capacity, but this will first work when the charger software is fixed.
  18. #5118
    Since owning the charger am wondering if it is possible to use a dummy cell with proper connections to test lithium polymer cell phone batteries.
    Has anyone got any experience in such hack?
    If possible, what would the settings be to test capacity?
    Thanks
  19. #5119
    Oct 2013
    USA
    ^^^ See the prior thread testing smartphone batteries.
  20. #5120
    Quote Originally Posted by Gauss163 View Post
    Thank you!!
    This is what I was looking for.
    BTW, can other owners confirm the data gather resolution in terms of significant figures for Voltage using DEX?
    My data only shows two but have noticed that some charts and data tables on the web show three.
    Regards
  21. #5121
    Unenlightened
    Jan 2018
    Hello.
    What the method (which algorithm) does the device make when measuring internal resistance, Rac or Rdc ?
  22. #5122
    Flashaholic mrQQ's Avatar
    Jul 2007
    Kaunas, Lithuania
    guys, how can I try to revive deeply discharged li-ion with this? it says check voltage and does nothing
    don't judge a thing till you know what's inside
    flashaholic wannabe
  23. #5123
    Oct 2013
    USA
    It uses a DC test (current interruption), see the discussion starting here. And see here for why high-frequency AC impedance tests are less useful here.
  24. #5124
    Quote Originally Posted by mrQQ View Post
    You need to hold the corresponding slot button pressed, until voltage gets high enough for the chemistry of the battery to be recognized.
    Not 100% sure, but I suppose it would be around 2.5v or something similar for li-ion.
  25. #5125
    Unenlightened
    Jan 2018
    It uses a DC test (current interruption).....
    Thanks.
    Ri dc, good idea, but not good working in mc3000.
    I use Russian Standart test: https://www.google.com/url?sa=t&sour...3GgAU-sMb16zv_
  26. #5126
    Oct 2013
    USA
    Thanks. Ri dc, good idea, but not good working in mc3000.
    Not clear what you mean. Are you saying that IR testing does not work on your unit?
    I don't read Russian. Perhaps you could summarize for us.
  27. #5127
    Flashaholic* id30209's Avatar
    Mar 2008
    Croatia-Europe
    This question, i believe, needs a simple answer. Most of you are experts in this topic but some users are just begginers.
  28. #5128
    Jul 2007
    Kaunas, Lithuania
    I've tried that, but it also results in "Check Voltage" message...
    flashaholic wannabe
  29. #5129
    Just jumping into this thread, but on top of slot #1 failing on my mc3000, it can't properly read IR anymore on any of the slots. It's gone completely haywire with readings all over the place. Purchased it in feb of this year.
  30. #5130
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by klrman View Post
    Probably connection problems, you can try cleaning the connections on the charger, but the problem may be the internal rail connection (It is slightly more difficult to clean).
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
