The Fenix-Store
Page 16 of 18 FirstFirst ... 69101112131415161718 LastLast
Results 451 to 480 of 511
Thread: Test/Review of Charger Opus BT-C3100 V2.1
  1. #451
    Default Re: Test/Review of Charger Opus BT-C3100 V2.1
    I use the 3Amp provided adapter, EU version. It seems the problem with power adapters was during the charging, discharging isn't supposed to require a lot of current from AC.
  2. #452
    Oct 2013
    USA
    Yes, the earlier problems were with charging, which I thought was your case but double-checking I see yours has to do with discharging. Possibly some discrepancy may be due to different termination voltages but I would not expect that much. How were you measuring the current? Possibly your meter might not yield accurate results for pulsed loads.
  3. #453
    Arrow Re: Test/Review of Charger Opus BT-C3100 V2.1
    Quote Originally Posted by Coolfx View Post
    I recently got 2 BT-c3100 v2.2 to test capacity or my powerwall project and I found the readings a bit weird.
    I didn't noticed it first testing 2800-3000 mAh battery, given capacity of 1500 to 2800 seemed good, but I retested some old Samsung 26H I previously tested with a copy Imax b6 months ago (a lot were 2400-2500 on Imax) and now I got 2600-2700 at 1amp with these BT-C3100, more than the rated capacity of theses old cells.
    I'm a bit confused about the readings of theses chargers, I checked the discharge current with my multimeter and got 0.78-0.9Amp fluctuating for 0.999-1Amp given at the charger screen.
    Can I assume the charger discharge below the rating it's supposed but think he's in the range and give a false capacity ?
    I haven't found anyone with this concern with v2.2.
    I don't know how relevant this may be -
    1) mine is a v2.1 and
    2) way back in Sept/2014 -
    I had one slot that gave significantly erroneous discharge readings, where the measurements were more than double the actual capacity when measured in another slot.
    Please see Posts #55 and #59 (links) reported in this thread.
  4. #454
    Quote Originally Posted by Gauss163 View Post
    Maybe my meter isn't accurate with pulse loads,I used my usual meter with 20Amp DC current capacity.
  5. #455
    Quote Originally Posted by UnknownVT View Post
    Thx for your feedback, did you find a way to solve the problem on this channel ?
    1)Readings seems consistant between channels and units here, it's more like both chargers are badly calibrated.
    2)I don't really trust the capacity given by my old Imax b6 copy as it's cheap chinese stuff but I appear more realistic with 2400-2500 (and maybe too enthusiast ?) for a at least 5 years old 2600mAh battery.
    3)According to the mesured discharge current (86% min of displayed 1Amp) and the given capacity of 2700+ it should be a real 2300+mAh which seems possible for theses cells. If someone have an idea to check the capacity let me know.
    4) I also have a Skilhunt M4D charger, I will try to charge some cells discharged on the BT-C3100 and compare charge/discharge capacity.
  6. #456
    No, never resolved. Got partial refund - so I have an Opus BT-C3100 V2.1 with 3 good channels (slot #1 one of the higher current ones is bad and I marked and just don't use it)
    Since then I bought another (v2.1) when the price dropped.
    My suggestion - if you are not satisfied with the charger - return for replacement or refund.
  7. #457
    Oct 2007
    Connecticut
    I have had this charger for a few months and love it so far. Have been slowly churning through my Eneloops, analyzing and charging them. I love being able to charge both battery chemistries without issue. Great tool!
  8. #458
    I bought this charger some days ago.
    He is so great and seem to work find.
    But when i plug the back power of charger i got some electrical sparks.
    Should i be worried about that ?
  9. #459
    Quote Originally Posted by er84 View Post
    Can happen with dc adapters.
    I find it best to plug the cord into the charger first, then the cord into the wall.
    Great charger, though.
  10. #460
    Yes i will do it like this, seem more safe.
    I also read its normal, its about the capacitor instant charging.
  11. #461
    ...for normal charging I will still prefer a charger with non-pulsing CC/CV charging.
    Does anyone know why HKJ prefers non-pulsing CC/CV charging? What's wrong with pulsing?
  12. #462
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by seanspotatobusiness View Post
    With smaller cells, you may charge with 10 times rated current in the pulses.
    When the charge is nearly finished a pulsing charger will often charge with voltage above 4.2V.
    Both are minor details, that is avoided with a non-pulsing charger.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
  13. #463
    Banned
    Aug 2013
    Valley Forge, Pa.
    I like mine very much. I exchanged my original 2.2 for the one below which gives a slightly higher charge[0.02v] and is more accurate w/ capacity test!
    HKJ Tested:2884Mah for FT version
    DISCHARGE/CAPACITY RESULTS
    Device: NEW Opus BT-C3100 2.2
    Battery:Samsung INR18650 30Q- FT-3000mAh
    Purchased:November 27th,2016
    Discharged @ 1amp
    Cycles:5
    Four slot average:2925mAh-HKJ-2884mAh-My Opus results are 1.5% higher than HKJ.
    __________________________________________________ __________________________________________________ _______________
    Battery:Samsung INR18650 30Q-BT-3000mAh
    Purchased:March 27,2017
    Discharged @ 1amp
    Cycles:1-Brand new-First cycle for this capacity test.
    Four Slot Average:2910mAh. Although it is a BT and Not a FT which is the only one HKJ tested, it is 0.9% higher than HKJ[2884mAh].
    __________________________________________________ __________________________________________________ __________________
    As you can see they are very close. The OLDER[4+Months] FT 30Q have a Four slot average of 2925mAh and the BT'S have a Four slot average of 2910mAh
  14. #464
    Flashaholic SoCalTiger's Avatar
    Mar 2017
    Southern California
    What is the practical impact of this? More wear/degradation of the cell over time I assume? Is there any impact to cell safety over time or just cell life? Or maybe no practically measurable difference at all?
    It looks like the pulses are at a little over 2A - about 2.25A. So, for a 2Ah+ cell, no problem. But I can see how it can be problem for a smaller cell that is say, only 600mAh. The pulses are at ~4C in that scenario.
  15. #465
    Mar 2009
    USA
    Has anyone compared the Opus 1000 with the 3400 for charging ability and speed?
    Oveready Boss 35 & 70; LensLight Mini; HDS Rotary 325 XP-L, Clicky 170W; ZebraLight SC 600 MK III HI, SC600W, SC62W, SC60W, SC52W, SC51C, SC5W; EagleTac NW D25LC2 Tactical, NW D25LC2, NW D25A, DX30LC2 Clicky; Fenix PD35; Nitecore D10R2 and D10R2 (Tribute); Elzetta Alpha
  16. #466
    Quote Originally Posted by gyzmo2002 View Post
    Results for the Opus:
    Discharged capacity measured: 3502mah instead of 3252mah with the mc3000. The capacity measured with the Opus is too high than the cell specs.
    In then process of testing hundreds of 18650s here and the results really are a bit high. Ive had several that the 3100 v2.2 says it's discharged 2200-2250 from a 2000 cell.
    Considering this inaccuracy seems normal I'm trying to find out as accurately as possible what percentage on top it seems to be. From my results I'm inclined on say about 15%.
    As you have the mc3000 would you mind running a few more tests so we could maybe establish an average percentage that I can take off the results from the 3100 so I know what my cells are so I can categorise them?
    cheers mate
  17. #467
    People are saying the opus charges to 4.22v, mine definitely stops at 4.2, what gives?
  18. #468
    Mine stops a 4.2v as well. Might just be a tolerance issue. Most cells are specified +/-0.05v on he charge voltage.
    Mike
  19. #469
    Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    Quote Originally Posted by The-J-Man View Post
    Chargers are all different.
    I have some that charge to only 4.14v-4.15v (Xtar MP1S), some that charge over at (4.22v-4.23v (two Liitokala 100s) and finally, some that are just right--4.20v (Xtar XP1).
    There's tolerance stacking even within the same model line there could be variances and then throw in the condition of the cells and batteries and things can be 'not always exact', shall we say?
    I even have two Liitokala 202s that I got at the same time and but for the extra bay, the 202s are identical in my eyes to the 100s, but both 202s consistently undercharge to the tune of ~4.18v, for all four bays! Even on the 4.35v setting for my LG D1s/E1s.
    My Opus BT-3400 v. 2.2 seems to terminate right at 4.20v for the times that I've sat there and watched, with healthy cells coming off at 4.19v-4.20v and then settling down a bit after that, which is normal.
    Spec for most cells is 4.20v (+/- .05v), so 4.15v-4.25v and the health/condition of the cells will matter a lot. That means where the charge curve stops and not where the cell is 24 hours later.
    It used to be that the NiteCore i4 v.2 charger would exceed spec for many users posting here, to the point that some might not have been that kosher to use, but mine has been a perfect child...go figure?
    Get a decent DMM, get a fresh battery for it and check this stuff initially, at least, so you know what's up.
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
  20. #470
    I just got myself a second one and the Voltage reading are terribly wrong. A 4.20v cell reads at 4.13v. My first charger reads it at 4.21v.
    Is it possible to calibrate these chargers, or is my unit just defective?
  21. #471
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    When people say this I always wonder what equipment the use to check the charger. The meter has to measure the voltage in the 0.2 second the charger turns the current off (My preferred meter for this is a Keithley DMM7510, but it is a bit expensive).
    With that said the precision on these charger is not that good, but I believe somebody said it has a very rough calibration (Something with a solder bridge).
  22. #472
    I got some 40€ multimeter from amazon that had a 5star rating, its been just as accurate as some super fancy one I have at work.
    My first c3100 is a tiny bit high compared to the meter but the second is quite a but low.
    so there might be a chance to adjust how its calibrated?
    I put some cells in it now to charge them, they are reading 0.02lower then my meter so im ok with that, lets see what they charge up to...
  23. #473
    Mine was showing 4.2v when it was really 4.16v fully charged ,I did a bit of research on this forum & came across a thread that discussed desoldering the J1 solder blob , I did it and now it's only 0.01v off , it now shows 4.2v & my multimeter says 4.21v.
  24. #474
    Banned
    Aug 2013
    Valley Forge, Pa.
    Quote Originally Posted by Nev View Post
    That is interesting.
    My first one showed 4.20v. The DMM read 4.15v. I exchanged it for that and other reasons!
    My new one reads 4.21v. DMM reads 4.18v. Plus its capacity results are much more accurate to specs. No complaints w/ this one.
  25. #475
    I tried to find the thread so I could post a link to it ,but I can't find it ,I was only reading it 2 days ago.
    I've got pictures of the circuit board where the J1 bridge is but I can't post pictures on this forum for some reason, I had to use a magnifying loop to spot it as it's very small.
  26. #476
    Banned
    Aug 2013
    Valley Forge, Pa.
    You have to use a Host to post pictures on here. I use postimage.org. It is simple and works much better and faster than photobucket which I used prior to Post image.
  27. #477
    [IMG][/IMG]
    j1 as it came
    [IMG]
    [/IMG]
    this is after it's been de soldered.
  28. #478
    [IMG][/IMG]
  29. #479
    Wow thats a tiny solder bridge!! how did you manage to fix that
  30. #480
    With a 10x magnifying loup
