i cannot find the info i'm searching for to build a flounder light. what's inside those PVC flounder lights as far as the actual hardware used to drive & cool, etc...?
i can build it, i just don't know exactly how to wire it up. i am NOT concerned with how to make or waterproof the housing. i need help with the guts. need to know which parts to wire together & how to properly arrange them. i assume i need an emitter, connected to a heat sink, wired to a driver, wired to a battery as the basic idea, but that doesn't give me a whole lot in practice, lol
if possible, i'd love to use the same deep cycle marine 12v battery which cranks the boat, but if i need to add another deep cycle battery dedicated to the flounder lights then i can do that. ideally i'd want 2 batteries, but if i can make 3 lights that run at low enough amp draw to gig flounder for 2 hours off one battery then have juice enough to crank the boat, that would be awesome, then i can just alligator clip my contraption to the boat & hit the water.
hoping to buy the parts & make this myself, but i am not sure where to start. i can handle the pvc housing & mounting to the boat part. what can y'all recommend for the emitter, the driver, the heat sink, & how the heck do all those connect to each other? I can wire it up & solder it, i know to use high heat epoxy, etc..., just need a little guidance. white to warm white is the color of choice. if it can flood far & spill too that is going to be good i think? it needs to illuminate the bottom of the waterway 4+ feet from the boat, in 2-6' deep water aiming around the bow of the boat with about a 120 degreem beam. this means multiple lights are required. i plan for one aiming forward, and one or two aiming off the side. i will be running a bank, so i don't need to have 180 illumination around the bow of the boat on both sides, just forward & one side. the brighter the better. thanks in advance.
