Hi
I hope this is the right forum. I have a 18 bulb chandelier with FEIT Conserv Energy 9.5watt LED bulbs (Item 144799). I need a dimmer switch that can handle the load (171w). Most LED dimmers handle 150watt. No 250 watt LED dimmer is compatible with these bulbs as far as I can tell from: http://www.feit.com/Dimmer_Compatibility
Lutron makes a 250 watt LED dimmer. That is the same model as some of the others on the FEIT compatibility page but is 250w where as they are 150w.
Question; I am guessing I could just use the Lutron 250 Watt dimmer and I would be fine even though it is not on the compatibility list. Any thoughts on this?
Thanks for your help
