I noticed this new Hotshot variant at a distributor's site. It claimed to have a wider beam than the classic Hotshot, so I got one to check out. The optic has a diffuser-like grating.
Beamshots show steady-burn intensities (Hotshot maxed out, Micro on HIGH). Same f-stop and exposure.
Notes:
1. unlike the Hotshot or Hotshot SL, you cannot adjust the frequency of the flashing modes on the Micro, or the intensity of the steady-burn mode.
2. unlike the Hotshot or Hotshot SL, the Micro doesn't have a clip on the light, so it's not suitable for clipping to the rear of a seat bag, hydration pack, etc. The lack of a clip also means there won't be an optional bracket for mounting the Micro on a rear rack.
3. the charging port on the Micro is MicroUSB, not MiniUSB, another difference from the Hotshot and SL.
4. The "Group Ride" mode is a low-power steady-burn mode. "SteadyPulse" runs the light at a baseline intensity with a triple-burst flash pattern on top, similar to DiNotte's well-liked quintuple-flash-over-steady pattern.
5. the Micro's single-flash mode runs at a pretty high frequency. It appears to be similar to the Hotshot at its maximum flashing frequency.
6. the button has a tactile and audible click.
7. despite the "Micro" name, it's very similar in size to the regular Hotshot or the SL.
Subjectively, I observed them both in steady-burn mode from various angles on my seatpost to estimate their relative intensities from different angles. Someone at your 1-3 o'clock approach is more likely to see the Micro (as long as it's not being obstructed by your leg) because its body protrudes more, and there's just more of it to see. From your 4 o'clock to 5 o'clock area, the Micro looks marginally brighter. From your 6 o'clock (direct rear) the Hotshot's very focused beam is the strongest.
Overall, I would generally recommend the regular Hotshot, and just make sure to hard-mount it and aim it precisely. I like the adjustable flash rate, it has the option to clip to a seat bag loop or a hydration pack, the mount is more secure, there's a rack mount available, and personally I like the stronger centerline intensity for daytime use in this age of texting-impaired motorists. Also, I've just never been a huge fan of rubber strap mounts, although this one is pretty robust for the weight of the light.
Where you might want the Micro, is if your only mounting option is on a seatstay. The classic Hotshot's mount has a release tab that often hits the stay and forces the light to be mounted aiming upwards. The Micro's mount has its pivot at the bottom and would be able to aim the light level regardless of the frame's seatstay angle. Hanging it from beneath your chainstay is another possibility.
Notes:
