Just having some fun and learning how to use my new 6.5 digit bench DMM. It's an Agilent 34461A with a fresh traceable calibration certificate showing that 4 digits right of the Decimal is absolutely accurate. The 5th and 6th digits could have some error. This is a Trend Plot of a battery charge using a FMA Revolutrix Dual Power Lab 8, 2800 Watt hobby charger. The pics are a 1-minute screen shot at about 25 mAh before termination. The cell is a 350 mAh 10440 and the charge rate was initially set at 185 mAh. Termination was set to C/20. The charge appears to be pulsed at about 2 pulses per second and as fast as my meter caught it, it doesn't show the Voltage falling to 0, just fluctuating about 22 mV between high and low. I'm fairly sure I could have set my meter to read faster but forgot to try doing it. This might have shown a greater difference between the high and low Voltage readings. Second shot shows 45 seconds after termination.
