CyclingSalmon14
- Joined
- Feb 10, 2014
- Messages
- 944
SCROLL DOWN TO POST 12
I am getting a XPG2 Triple (6/7A) and will get some hybrid IMR at some point.
(can't be using unprotected as don't want to mounter voltage between uses, only before and after charging)
But until then k will be using a standard 18650 3400mah Protected panny bases Xtar.
I understand I will loose some proformance but but gain runtime - that's fine for me.
But how big will this effect be? Light is rated by vinh at 1800 lumen's (with hidrains - Emitter lumens not OTF) he reckons I'll see runtimes of 40mins on high using this standard non high drain cell.
(obviously that's not in one go as it steps down after five mins)
If I popped in a protected higdain how would this effect runtime aproxemtly and how big a difference in proformance?
What can I expect to see proformance wise on a non IMR (standard cell). (1200 lumen more less?)
I know this is all very rough and guess work but curious on just how big a difference Hidrain makes vs Non hidrain.
I'm not sure what you're talking about with the voltage monitoring?
If you use IMR you don't have as much worry about the cell doing violent stuff, so IMR cells don't tend to NEED protection circuits the way (std 18650) ICR do.
I mean I don't want to worry about my voltage getting to low, as if I used a Unprotected cell I'd have to keep checking to make sure I don't over discharge it.
Not a safety issue but a issue of practicality, with hybrid IMR or standard protected I can run until protection kicks in, may seem like an easy thing if just playing with the light not to run it down to dar but if I'm ridding with it or I'm generally using and need to use the full charge I don't want to worry about over discharge and killing the cell, hence why I will be buying some protected high drain cells.
If you use the std protected 18650, you will not be able to support the amp draw very long, reducing the runtime at max output, not increasing it.
yes of course, i mean I won't be abke to reach its max potential without high drain cells as standard cellsimole can't out out the nessery ampage, but due to this the runtime will b longer on Max with a standard protected 3400 than it would be with a hi drain even if the high drain was the same capacity simply due to the lower out out of the standard proteced cell.
i am correct in thiking if I ran the light at max a protected ,3400 will last longer thana high drain cell even if the high drain cell wasthe same capacity? (Ofocurse there not there nornaly less)
If the light turns off when the cell can't supply the amps, it won't over drain the cell. If the light steps down when the cell can't supply the amps, it will just get dimmer as your warning, etc. If its a direct drive that simply dims slowly as the cell draws down, you (Manually) need to notice when dim "enough" to be "Too Dim/Too Drained".
yes I understand this
That tends to require the use of a DMM when the light dims, at least at a few initial points/trials, so you see what voltages are associated with how much dimming (And then you do it by eye w/o the meter once you have a feel for that light/cell combo). When you see how dim is associated with the low voltage mark of interest, when its that dim, you know its time for a fresh cell, etc.
yes that's my point with a protected I can just swap it out when protection clicks in, no need to keep an eye on anything.
The light might have 10% - 15% higher lumens with a corresponding increase in cd on the high drain (IMR) cells vs a protected 18650, although, depending on the circuitry, the ICR 18650 may not be ABLE to supply 7 amps, and, the output could be 1/2 rather than a 10 - 15% loss, etc.
I want to assume you are talking about a triple P60 drop-in, correct? The light is using only one 18650? That means that your driver will either be running direct drive or maybe regulated.
There is just no way that you will get 6-7 Amps draw off a ICR cell. The internal resistance is way to high. Maybe you'll be able to get 4-5 Amps if you are lucky but the battery voltage will drop very quickly and so will the current. Best Ri (internal resistance) you are likely to get from a ICR is around 70-80 mOhms. When I tested some cells that were about 1-2 years old their Ri was closer to 150+ mOhms.
You need an IMR cells to get the full current off this setup. A Sony VTC5 has an Ri closer to 10-15 mOhms. I have some Panasonic hybrid 2500mAh batteries as well and their Ri was measuring around 20-30 mOhms.
I've tested the Sony VTC5 on a 6Amp triple I made and I was able to get a full 6Amps. It didn't last for a really long time before the current started to drop as that is a high load for even the best cells.
Keep in mind that any runtimes will also experience lumen drop-off through the run. You may only get that 1800 lumens for 5 minutes. Also - heat will be a big issue. You won't be able to run that light on high for the full time.
Summary - I don't think ICR 18650s are appropriate for this setup. Protected or not you will be pushing this cell too hard and the cycle life of the cell will drop dramatically as well. Get a good IMR cell. If you can't find the VTC5 you may want to try an eFest IMR 2500mAh cell.
Which are the best protected high drains, I believe in my other thread (EDIT: Now this one) some one said there called Hybrid's.
All the benefits of a High drain so I can run vinhs lights that need high drains but also have protection, obviously at the added expense of protection and less mah but that's fine for me, Ill use standard cells in the ones that don't need so much power.
Aka which ones are the best, most power but still good mah? Obviously they won't be as strong as a Sony VTC5 but should be ample for vinhs lights?, Much better than standard cell and allow the lights almost there full potential, and great for running in multiple cell setups.
Whare can I buy in UK I don't see them on any of my usual flashlight sites.
Something like this is probably what you want:
http://www.ebay.com.au/itm/2x-BLAZA...ronics_Batteries_Chargers&hash=item416d2a08dd
Tested to 10A continuous with one of the best protection circuits available, 3400mAh.
Not cheap or local to you though...
Tested by who? The cells you linked to are based on the bog-standard NCR18650B...not a high drain cell at all. And some of those graphs are just wrong, or at the very least, misleading. I don't see any 10A tests, and for good reason...protection would trip long before it hit 10A. And even if the cell could do it, the capacity would be extremely low under that type of load.
Some of the graphs have no axis labels, so they could be measuring anything at all. It doesn't say. The very first graph on the page you linked is one example. No actual labels...just numbers. But it LOOKS like voltage on the Y axis, capacity in mAh on the X axis. If so, they are just lying to you. Shows a measured capacity of 4000 mAh. A very big red flag...there is no 18650 available anywhere, regardless of chemistry, that can provide 4000 mAh. Ebay is a terrible place to buy batteries, in my opinion. Too many fakes, and too many marketing lies.
Tested by Yass himself. He showed me graphs on his computer, he is the Aussie equivalent to HKJ, has all the testing gear, rooms of it. He had 4 of the above in his FFIV and it ran on turbo no worries and didn't warm up and slower than PF's.
He used to be into lights, now he is a vaper. He knows what he is talking about.
They are NCRB's with a high quality protection circuit he designed himself (electrical engineer)
Thak you, would hybrid cells (Protected panny IMR things) be a good compromise?
I had hoped I'd get away with only a little loss on a standard cell, did not realise they were that weak, I thought the IMR were for silly powerful things that are 10+ amps. Hmm OK thanks for the information I'll look into the hybrids, as this will be on my hekemt and I'm ridding I don't want the worry of over discharge.
Yhea I knew I'd only get 1800 for the first few mins ahaha, that's only for when I really need it and most of the time it will be on low or medium.
I have some old xtar cells I'll use until I can buy some hybrids, as I don't mind if they suffer a bit. And should be able to cope on the lower modes.
Cant wait, will be my first P60 style light and my first triple, I'm a bit worried JM going to want more hosts and start buying more dropoins....
Thaks all!
I bought XSTAR batteries from battery junction and they are relabeled Sony VTC 5's. Best I can tell, they are real and perform very good. I have 8 of them now and they all look the same and all perform the same. They make my MM15 and PD35 triple much brighter than a standard battery. They are also reasonable priced.
