Quick HDS question...
Valpo Hawkeye
Valparaiso, IN
I know there are thousands of posts on these lights, but sifting to find the answer leaves the question alive for me:
If I do the "20 click turn programming on" move on an LE Clicky can I reprogram it to be an executive-type setup?
Moonshadow
Scotland
Yes, on these two models you can customise each of the four preset levels so you could reprogram the LE to behave like the executive and vice-versa. The only difference is in the default settings that it will go back to if you do a factory reset.
