How bright was the light at the end of the 72 hours? Remember that ANSI run times are listed as to 10% of initial output at the 30 seconds of run time mark. I would expect the Eneloops to have shorter run time but to hold output brightness much better, particularly if run in multiple AA adapters rather than using the 1 AA for 1 D type adapters. AA to D adapters are available in 1, 2 or 3 AA into 1 D versions.
The LED in the Ozark Trail 300 lumen lantern and the 3D Mag are both small die Cree LEDs, and should have similar output and run-times. IE, one will not be more than 10 more efficient that the other. Therefore, since both are NOT regulated, you should expect similar output and runtimes, especially since it has been noted that run-times are similar.
Here are the estimated outputs for the Ozark Trail lantern (pulled from the thread I linked to above.)
On 3D Alkalines:
Initially the lantern pulled 700 ma high, and 390 ma low. ~210 lumens, and 130 lumens.
At the end of the first hour it was down to about 175 lumens
And at the end of the fifth hour it was just above 120 lumens.
For the seventh through seventeenth hours it was between 100 and 110 lumens.
Hours 18-28 it was between 80-95 lumens.
Hours 29-40 were between 70-80 lumens.
Hours 40-55 were between 40-63 Lumens
I quit at 72 hours where it was still running and putting out (a guess of) 10-20 lumens.
On 3 single Duraloops:
See
here for more information.
It was pretty steady @ about 128 lumens for the first three hours
by the end of the fifth, it was below 100
by the end of the 7th, it was DONE @ about 20 lumens
