Hi all-
I'm looking to add an upwash light fixture to a ceiling fan. The fan's halogen output is too low and the shadow cast by the blades on the ceiling is somewhat annoying (it's a large 72" fan, pretty wide blades).
I was thinking of installing a small fixture I would make myself on top of the motor assembly. There is room for a 6 inch diameter ring of lights, 1 or 2 concentric rows of LEDs, prefer 4000k color, to be controlled by a separate lighting circuit from the fan. I have a mill and lathe, so machining a heat sink is no problem. Just need to find a source of LEDs in that color range. Any suggestions?
Thanks!
Thanks!
