How bright can LEDs in electronics be?
The application is in a digital audio mixer that is used outdoors and indoors.
A lot of people complain that it is hard to see the indicators on a digital mixer when used outdoors. Well I have had the exact same problem and sometimes even worse seeing them on an analog mixer outdoors and those panel lights usually aren't LEDs. But usually on an analog mixer there is a physical button that you can (not always easily) tell if it is up or down. With digital you are really relying on being able to see the indicators.
Are LEDs just not capable of being bright enough or are they too expensive to use in this type of gear? Every digital mixer that I have used to the best of my knowledge has the ability to change the intensity of the indicators and it is usually a separate control from any other. You don't want it to be too bright when used indoors but they never seem to be bright enough outdoors. There is or was one analog console that used blue lights as indicators that indoors they were just too bright and there wasn't any way to turn them down. That wasn't good and it was the only thing I didn't like about the mixer.
So why are the LED indicators not bright enough? Is it too expensive to use brighter LEDs or are they not made as bright as they would need to be? Or if they were capable of being bright enough what are the other problems introduced? Can the same LED be bright and without a problem also be very dim?
Or do the manufactures mixers not realize these products are used in sunlight situations where it is critical that we be able to see the LEDs and we can't?
Would it be cheaper to design it with dual LEDs a dim one for indoors and a bright one for outdoors. Or to design a dual LED one that has both bright and dim functionality in it. This would probably not be something that could be easily retrofitted into existing mixers but might be able to be done in a new design.
I am not the kind of person that likes to accept the status quo I like to come up with solutions to problems. And seeing the indicators on a digital mixer out of doors is a problem that I have not seen anyone address completely yet.
I would really like to hear from someone with experience manufacturing this kind of thing.
