Hi,
I am a newbie and was hoping for some guidance. I just purchased a Nitecore D4 charger to supplement my D2 charger. I had some Olight 3400 18650s that I used for a few minutes in a Thrunite TN30. After use, I tried to "Top them off" in the new D4 charger. I returned about an hour later and it was still showing as charging, which was strange since they had barely been used. To double check, I placed them in my D2, which immediately displayed a Finished Charge message. I then placed them back in the D4 to double check and the D4 continued to try to charge them.
I was then concerned that the D4 was defective and may have overcharged the Olight batteries. They are protected (and way too big to be called 18650, but thats a different issue). I checked the batteries with a cheap multimeter I have and they are showing 4.15v. Would you say these batteries are still OK to use? I definitely plan on returning the D4, but wasn't sure if I should be concerned with the cells.
Any feedback is appreciated.
Thanks!
Rob
Thanks!
Rob
