In my home, we have three 48" fluorescent fixtures. I wish to replace these with LED lights with a high CRI. I am currently planning to use Cree "TrueWhite" lights.
I need to decide between using the Cree drop-in replacement T8 bulbs that run off of a ballast (CRI 90), or the Cree Linear LS4 (CRI 92), or some third option.
I've never seen a Cree LS4, just photos of it. It's the size of a single fluorescent bulb but as bright as two bulbs (4000 lumens). I'm wondering if it will be too bright and will annoy us, or if it will be fine.
Two of the lights I need to replace are in the kitchen. In the ceiling there are two long rectangular boxes, with a fluorescent fixture inside each (T12 bulbs) and a plastic diffuser panel. If I stick an LS4 inside each, will it look about the same as if I put a pair of Cree T8 bulbs, or will it seem harsh?
The other light is in the master bathroom, over the mirror, inside a smooth white diffuser. (It looks like a Lithonia Litepuff vanity light as shown on the Home Depot web site.) Currently the whole thing glows pretty evenly... with a single tube at twice the brightness would it look different?
I would actually prefer to have a custom power supply designed for LEDs, rather than using the Cree T8 bulbs with a fluorescent ballast, but perhaps I'm being silly.
If you have a third option to suggest, please do so. But please don't suggest I just switch to high-efficiency fluorescent bulbs; we want to use LED lights.
Also, what color temperature do you suggest for kitchen and bathroom? I was planning to go with 3500K for both.
Thanks in advance for any advice you can give me.
