Klarus
Page 1 of 6 123456 LastLast
Results 1 to 30 of 160
Thread: M2Xvn
    Default M2Xvn
    M2Xvn
    Must Read & Agree Before Purchase Click here
    Factory Link Click Here
    Photos in Post 2
    $135 You pick XPG2 PDTc or XPL Hi 6500K
    Extra Upgrade:
    + $35 DriverVN2
    + $15 LED copper heatsink sand flat and buff shinny + new arctic silver thermal compound,
    larger LED wires, switch and spring mod
    + $5 "V54" hand engraved
    + $15 for International Shipping
    + $5 Blue rubber boot: larger press area, thick material, higher sensitivity, better looks
    + $10 Single Mode Only
    If You Want Shipping Insurance Please Ask
    Paypal/Email: vinhnguyen54@gmail.com
    Flashaholic* jmpaul320's Avatar
    Mar 2012
    CT, USA
    Default Re: M2Xvn?
    M2X Stock VS M2Xvn W/ U3 PDTc Direct Drive (Both 4 mode driver and single mode only are direct drive)
    Blue rubber boot optional upgrade
    Default Re: M2Xvn?
    Quote Originally Posted by jmpaul320 View Post
    I was waiting for this. Factory driver doesn't like high current from what blf modders say. So maybe a fet driver and a pdt xml2 is the way 2 go?
    Its really a shame to bin the factory domeless LED but I really hate the tint. May be I have more greener than normal samples.
    I am happy to realize how happy I am. Thus, a chain reaction of happiness.
    SkyLumen54@gmail.com
    Mar 2012
    CT, USA
    Default Re: M2Xvn?
    I'm not surprised though. Olight doesn't stock pdt like u do lol
    Flashaholic* aginthelaw's Avatar
    Jan 2007
    NJ, USA
    Default Re: M2Xvn?
    dang it...just when i thought i had everything...looks great as a stock light...i'm just imagining what can be pushed out of it. i really liked the way they shipped a sample to that blf guy and he mods it replacing resistors and such. i guess samples don't have to go back?
    a single sunbeam is enough to drive away many shadows- St. Francis of Assissi
    Flashaholic* Ryp's Avatar
    Jul 2013
    Default Re: M2Xvn?
    Finally a cheaper M25C2vn.
    Enlightened Ltruelove1's Avatar
    Oct 2011
    Warrington pa
    Default Re: M2Xvn?
    I would be very interested In this light
    Flashaholic* tyxxvxl's Avatar
    Jun 2014
    S.L.C. UT.
    Default Re: M2Xvn?
    Maybe Olight got ahold of one of Vinh's lights and revers engineered it :-)
    Still not good enough though ha ha
    Ty
    PD35VN XML2-PDT, TK75VN-KT, SF P60VN2T XML2, SF P60VNT XPG2 FIAT LUX, S200C2VN, K40VN FIAT LUX, M2500vn, COPPER XPG2 TRIPLE, M25C2VN KT, CQVN XPL 4000K, MM15VN FL
    Banned
    Aug 2013
    Valley Forge, Pa.
    Default Re: M2Xvn?
    I hope you decide to mod more than the Two samples you have! Now that you opened it up It seems that there may be more hope than your initial thoughts to me!
    I can tell you the stock version was NOT even close to getting hot after running it 30 minutes on max! In fact it was barely warm!
    A gentlemen from CPF and BLF got these numbers,,,,,you must surpass them!!! He posted these numbers on my thread.
    so mine now does 278.75Kcd with 1435 lumens, 6.37A current draw.
    Default Re: M2Xvn?
    Quote Originally Posted by Capolini View Post
    6.37A?! can't beat that
    Banned
    Aug 2013
    Valley Forge, Pa.
    Default Re: M2Xvn?
    Quote Originally Posted by vinhnguyen54 View Post
    Does that[6.37A] seem realistic or accurate?
    I learned that the XPG2 after 4A does not get much brighter but I am unfamiliar how hard and XML2 can be pushed?
    Mar 2012
    CT, USA
    Default Re: M2Xvn?
    Xml2 - 7 to 8 a.
    My maxtoch is running at 7.7a to the led
    Banned
    Aug 2013
    Valley Forge, Pa.
    Default Re: M2Xvn?
    Xml2 - 7 to 8 a.
    It is coming back to me! I think the TK61 is ~ 7/7.5A W/ original at least 6.5A.
    Maybe because it is a smaller light he can not surpass 6.37A?
    Mar 2012
    CT, USA
    Default Re: M2Xvn?
    Could be.
    Flashaholic* chops728's Avatar
    Jan 2014
    Swampland,La
    Default Re: M2Xvn?
    Xml2 - 7 to 8 a.
    With the newer LEDs coming out It's been hard breaking 6amps with a XM-L2 5.4 seems to be the new normal--From what I've seen 7.7 is rare The 2 best I have hit 7.2
    K40Mvn (5k/4k domed/dedome) SR52vn(PDTn/PDTw) P15vn P16vn(PDTw) P12(PDTc) SRT6vn(PDTc) PD35vn(2c domed/PDTn) TX25C2vn V2T S200C2vn(PDTn) TK61(PDTc) LD50vn (PDT)
    M2Xvn (PDTsw) MX25L3 (4k) TN32(PDTc) TN36vn(dedome)
    Mar 2012
    CT, USA
    Default Re: M2Xvn?
    Quote Originally Posted by chops728 View Post
    With a single battery yes but with a buck driver it's a bit easier. The 7.7a I'm running is with a resistor modded 2x 18650 buck driver... Its also a u2 not the newer u3 which seems to be stubborn with high current lol
    Jan 2014
    Swampland,La
    Default Re: M2Xvn?
    Even the latest U2 are stubborn The question has been are they putting out the same at lower current
    Default Re: M2Xvn?
    U3 bin appears very bright even at lower current. I will do more testing on this in the M2Xvn. However there seems to be quite a big spread of samples and current draw all round.
    Banned
    Aug 2013
    Valley Forge, Pa.
    Default Re: M2Xvn?
    Default Re: M2Xvn?
    I will try to so a test for Old U2 VS New U2 VS U3
    Banned
    Aug 2013
    Valley Forge, Pa.
    Default Re: M2Xvn?
    That is what I was thinking,I sent you an email w/ pertinent info. regarding this!
    Jan 2007
    NJ, USA
    Default Re: M2Xvn?
    thanks for helping out bro. i really like what i read about this light and if anyone can make it perfect, vinh can. I wish i had the knowledge to put my 2 cents in
    Default Re: M2Xvn?
    For what it's worth...
    Factory M2X Domeless LED draw ~5.2A direct drive, Celing bounce no reflector ~55Lux
    XML2 U2 PDTn draw ~4.7A direct drive, Celing bounce no reflector ~60 Lux
    XML2 U3 Dedome Draw ~4.7A
    direct drive, Celing bounce no reflector ~62 lux
    Random old probably U2 Dedome Draw ~4.7A direct drive, Celing bounce no reflector ~60 lux
    Random old probably U2 dedome Draw ~4.3A direct drive, Celing bounce no reflector ~52 lux
    Tested with Sony VTC5. These are just one sample of each "class" so take it with a grain of salt.
    IMO I am just going to stick to U3 for max performance and efficiency with a PDTc like tint. It might draw less current than some old U2 but this is not happening consistent enough with reliable boost in brightness. At least not until I test a bunch more samples. Stick with PDTn if you like this tint.
    Default Re: M2Xvn?
    Post 1 updated. I will add outdoor beam shots later
    Prices are great if you don't add too many options. Great performer for just the base price. :-)
    Jan 2014
    Swampland,La
    Default Re: M2Xvn?
    That's my feeling--Pick the Tint you like that little bit of amperage difference on the top end is nothing
    Banned
    Aug 2013
    Valley Forge, Pa.
    Default Re: M2Xvn?
    If I decided to send you MY light and picked THESE options it would be $80?
    I JUST THOUGHT OF SOMETHING! WHAT ABOUT SINGLE MODE DD LIKE MY M25C2vn?
    1) +$35 Driver Upgrade: 5 minute High mode timer, High ~4.5-5A
    Pick your mode edition below:
    SL Edition : H-M-L-ML
    Always starts on H, 3-4.2V, Single IMR Cell Only
    2) +$25 LED copper heatsink sand flat and buff shinny + new arctic silver the
    rmal compound,
    3) +$5 "V54" hand engraved
    5) +$15 - U3 is brightest and is most cool white
    What is your estimate for throw[cd's] w/ the version I took?
    Banned
    Aug 2013
    Valley Forge, Pa.
    Default Re: M2Xvn?
    Can't you get closer to that than ~ 4.5 to 5.0A?
    I wonder how much more throw it will have than stock[3.8A] w/ additional .7 to 1.2A?
    Default Re: M2Xvn?
    rmal compound,
    Almost always more expensive to mail in light to mod VS buying directly from me. The price with the mods above + shipping = $100
    $70 if you want it single mode DD and the applicable mods above.
    I have no numbers estimate.
    Default Re: M2Xvn?
    Even Direct drive of a fresh charge Sony VTC5 and a good U3 sample I could only get around 5A with my Fuke 87V meter. I have a much cheaper $12 model MAS830 meter that I bought while I was in school that would read 6-7A :-)
    Flashaholic* Alex1234's Avatar
    Jan 2010
    Bear Delaware
    Default Re: M2Xvn?
    i cant wait to check out that xpg2 version of the M25c2vn. i want this light but i dont want my collection to get redundant
    Flashlights: X65vn,Tn42vn, Boss1vn, X6vn SSCU, X5 kronos, U21vn, m43vn, FD41vn, SDminivn, H20vn, E01vn, Catapult v5, Bkfa09s, XT15, S10R Baton III, 55w hid spotlight 1,100,000cd
