Aonsaithya
- Joined
- Dec 1, 2014
- Messages
- 13
Hello folks!
Styling-wise, my car has four distinct headlights. In practice, the inner ones (left) hold parking lights (W5W, small hole near the top) and main beams, while the outer ones hold dipped beams & indicators.
Curiously, the parking lights are on whenever ignition is on. Thus, when driving around town, I have two bright and two dim lights at the front.
I would vastly prefer something akin to this look (a somewhat long exposure photo mind you, with both dipped and main beams on):
The parking light appears to work primarily by just shining light directly forward rather than using the reflector in the light housing (to any meaningful extent at least). Now I'm wondering whether I could replace that W5W filament bulb with some kind of a LED bulb that would emit, or direct the light it emits, to rear & sides (so not front at all), thus providing the same function with indirect via the reflector. I believe that not only would it look nicer than just a single spotlight, but also even if the LED output is higher than that of a filament bulb, it should be no more dazzling as the light is spread over a significantly larger area.
Do you reckon there's any chance of this being successful?
Image tags removed see Rule #3 Do not Hot Link images. Please host on an image site, Imageshack or similar and repost – Thanks Norm
