Hi there new to the forum. Been lurking here for a bit and just want to confirm what I think I've learned by running some questions past you guys.
my wife drives a 2008 Mercedes ml350 with the standard (halogen) lighting. I believe both hi and Lo beams are H7 bulbs, not sure of the light's projector or reflector configuration. After a bulb recently burned out,I just threw in an oem replacement, but at the same time realized I had never been happy with the lighting on this vehicle.
After lurking around here it seems like the consensus is upgrading to Osama rallye 65w is the best choice? Is this correct? Should I worry about the extra electrical draw? Is the Phillips xtreme vision the best bet at 55w? Is there that much of a difference between these two? Any other recommendations?Should I also upgrade the high beams while I'm at it?
finally, the fog lights on this vehicle are pretty worthless (which goes without saying around here I guess). I live in a suburban area with little lighting and lots of deer that like to hang out just off the road. Is there an upgrade to the existing fog lights that would be useful in giving me more vision off the sides, a wider throw? Can I replace them with something like the hella micro de? Would the low beam upgrade be enough of an improvement to mitigate this issue?
sorry for all the questions but there's a lot of info out there and not all of it is good. Just trying to do the right thing after spending $30 on a couple oem bulbs that give the same terrible lighting.
thanks!
thanks!
