kj2
- For submission in the review section -
Olight has recently given their Baton series flashlights (S10/S15/S20) an update. These now include a rechargeable feature, therefor the "R" in the model name.
The rechargeable versions offer similar looks and specifications as the previous generation, except the included Olight battery and USB-charging dock.
Although they're similar I did three individual reviews for the S10R (1x RCR123/CR123), S15R (1x 14500/AA) and S20R (1x 18650/2x CR123).
Now lets get started
The packaging:
The S10R comes in a almost 'standard' Olight transparent plastic packaging. On the outside you'll find some features and specifications.
Now lets take a look what's all included.
Packaging includes: the S10R, a manual, Olight leaflet, lanyard, spare o-rings and split ring. On the bottom you will see a black cardboard box. This box includes the charging-dock and USB-cable. A manual that shows you
how to attach the sticky-gel pad. The included battery is already inside the light.
Features and Specifications: (given by Olight)
The manual gives information on specs, user interface and more. Always handy to read before usage
The S10R has similar dimensions as the older S10-L2. It's slightly longer and heavier because of the charging feature it now has. The led is well centered. The smooth reflector gives the S10R
some throw although his small size. The looks are kept quite the same compared with the older Baton series lights. The clip holds the light firmly and won't come off easily. It also clips good onto your belt or pants.
The clip still can be used in two ways, head up or head down.
Looking inside the light, there hasn't changed anything. The S10R, just like the S10-L2, uses a spring at the head for contact with the battery. Next to the spring you see the reverse-polarity protection.
New on the S10R is the recessed switch-button. This prevents the light accidental turning-on. In the middle of the button you see a clear spot. Underneath is a battery-indicator which let you know when, you have to change or charge your battery. The manual tells when you're using a CR123, this red-colored indicator will be constant on. I've tested this battery-indicator and it behaved differently than I thought. After a minute or 10 the indicator turned-on but the light was still going strong. I expected the indicator to start blinking when the battery was near empty. This didn't happen and the light turned-off when the battery hit 3.15V.
The "R" series has a new tailcap for the charging feature, but you can still twisted the tailcap for lockout. There are two contact points, an outer ring and a inner contact-point that magnetically connects with the charging dock.
Because one contact point is recessed, a short-circuit won't happen
The head on the S10R hasn't changed much, compared with the S10-L2. It still has the stainless steel ring and a GITD o-ring. My S10-L2 does have a OP reflector and a red o-ring, where the S10R have a smooth reflector and a blue o-ring.
The S10R has square-cut and anodized thread. The threads came well lubed out of the box.
Charging dock:
The included charging dock makes charging the S10R (as well the S15R and S20R) a piece of cake. No need to remove the battery and put it in a separate charger.
The S10R uses the same charger as provided with the S15R and S20R. It charges the light with 4.55V / 0.5A. The dock also has a extended USB-port for charging other electronic products. The output of the extended port
is 5V / 2A.
On the charging dock there is a led indicator which lets you know if charging is done. When connected but not charging, the led blinks red. When charging it's solid red and when charging is completed it's green.
The dock charged my sample till 3.92V.
Olight battery:
User Interface:
The user interface hasn't changed.
From Off: click to turn On in last used output mode. Click again to turn Off. When On press and hold to cycle between Low > Med > High.
To enter Moonlight, press and hold from Off. Double click from Off to enter High. Double click while On gives you a Strobe.
Lockout is also still possible (besides twisting the tailcap). From Off, press and hold for two seconds. To unlock, press and hold for one second. The light will automatically enter Moonlight mode.
Size comparison:
(From L to R: Olight RCR123, Lumintop ED10, Olight S10-L2, Olight S10R)
S10-L2 next to the S10R
And the rechargeable Baton family.
Indoor Beamshots:
ISO400, 1/125 sec, F5.0 - Canon 500D. Light approx 0.5m away from wall. Olight RCR123 battery.
Moonlight - Low
Medium - High
Outdoor Beamshots:
ISO1600, 3.2 sec, F11 - High mode
Pole about 20 meters in front.
Conclusion:
Olight has updated an already great light, and put it on a even higher level. The easiness of charging the light, makes the S10R a superb light IMO.
While keeping the same looks and UI, it still feels like a totally new light. Because of the complete package, you could even consider it a present for a non-flashaholic.
The light is still small enough to EDC and with the new recessed with you won't have to worry about accidental activation.
S10R was supplied by Adola for review, on behalf of Olight.
The packaging:
- NEW Low-profile side switch featuring a battery power indicator, which glows red when battery runs low
- NEW Includes patent-pending Micro-USB charging dock and a 650mAh RCR123A rechargeable battery
- NEW Thermal management safety program provides overheating protection by dropping high output by 50% after 4.5 minutes of constant on.
- NEW Glow-in-the-dark o-ring in bezel to help locate flashlight from accidentally dropping it
- 99% light transmittance rate through tempered glass, with two-sided anti-reflective coating
- Multi-function side switch with four brightness levels, plus a strobe mode
- Automatically return to your last brightness level with the built in memory function
- Removable two-position pocket clip
- Flat tailcap with strong magnet, giving you the ability to use the light as a hands-free worklight
- Highly reliable 6061-T6 aluminum alloy structure with ant-scratch, Type-III hard anodizing with a stainless steel bezel to protect against drops
- Reverse polarity protection to prevent improper battery installation
- Can be powered by one non-rechargeable CR123A lithium battery as a last resort in an emergency.
- Low standby current below 8uA
Charging dock:
is 5V / 2A.
Olight battery:
User Interface:
Size comparison:
Indoor Beamshots:
Moonlight - Low
Medium - High
Outdoor Beamshots:
Conclusion:
