Can a 6D Maglite hold 7D cells with short recessed tailcap?
bigchelis
Prunedale, CA
Hi all,
I was at my local hardware store and saw the 6D Maglites. I thought wow, an MTG2 direct drive off 7D cell would give about 8.4V input which is where the MTG2 works great. I know off the charger the NiMH Tenergy are 1.4A though and 6 of those give 8.4V too.
I know there are extensions for these D Maglites and might go that route.
Thank you,
bigC
alpg88
no. there is not enough mettal in D tailcup to bore out for extra cell, the o ring channel has a thin wall as it is, you'll lose the threaded part if you bore it out.
bigchelis
Prunedale, CA
Oh....well that pretty much explains it very well. Thank you.
For some reason I thought the 6D/7D Maglite would have ubber long tailcap springs to account for the extra weight of the 6D/7D cells.
bigC
alpg88
bigC
space between last cell and edge of the battery tube seem to be same for 2d and 6d, at least equal enough not to notice any difference with a naked eye. i did notice few diferent designs of springs in d mags, but i think it has more to do with different time of manufacturing than amount of cells, if you go to buy parts for mag from z battery, for example, all sizes of D mags have same spring (same part number). i think they designed spring that will have enough force for 6 cells and use them everywhere, this is a lot chaper that way than have special springs for every model.
