1996 Lexus ES300, 9005 high beams, 9006 low beams. In a correctly functioning car, the low beams are still on when the high beams are on.
Anyway, my problem is, the left low-beam harness wires got fried somehow. The left high-beam wiring is fine, and the right headlight wiring is perfectly fine.
I've had this issue for a few years, but when I first got it, I simply bought a Napa 9006 harness and reconnected and everything was fine for a few years.
But now, when I have the low beams on:
-The left low beam is very dim
-The right low beam works as expected
--BUT, both high beams are also on but very dim! WTF?
---Also, the high beam indicator light in the dash is on but very very dim.
When I have the high beams switched on:
-High beam dash indicator light works as it should
-Right high beam is on full brightness
-Right low beam is on full brightness
-The left headlight doesn't work at ALL! No high beam, and no low beam, either!
What could be my problem? Hopefully I don't have to spend too much money on it, because the car has other problems and I want to buy another car soon.
