I'll admit that subalpine thread was one of the threads that got me thinking. Scary stuff.
What happened to subalpine
is sobering, but so far we've insufficient detail and input from him to determine with certainty the cause.
What we can say is that, based on past incidents where further investigation eventually identified the cause, budget cells particularly in multi-cell light configurations are implicated far more often in these types of incidents than any other apparent cause.
I am
not saying subalpine is at fault
nor am I saying that the cells or charger he purchased are responsible. That said, given the reported nature of the failure, it is difficult to not suspect damaged cells played a key part in the incident. What's difficult to pin down is how the cells were damaged and when.
What isn't difficult to observe is that here is another incident of a significant failure of a
multi-cell lithium-ion powered light.
Good cells from a reliable maker/brand run in single-cell lights are virtually never implicated in these types of incidents. The anecdotal evidence strongly suggests that it is perfectly possible to design and enjoy a safe lighting system comprised of a known good charger (i.e. technically reviewed by HJK or 45/70 or other members here), good cells from reputable sellers, and well built lights - run by someone like yourself who is concerned about safety. If you want to reduce the risk and worry burden, only run single cell lights and sleep even better.
Bottom line: You shouldn't be concerned about the same sort of thing happening to you if you've set the stage differently.
Would I let young children play with li-ion powered lights? No. I'd rather they have access to lower-output lights (to protect their eyesight) and AA NiMH rechargeable power (to guard against the kind of abuse kids will sometimes dish out).
Now that my kids are older they use any light in the house.
