First time poster hoping to reduce my confusion about Quad 165x100mm headlight upgrades.
My daily driver is a 1985 Volvo 740 with quad 165x100mm headlights. Nighttime driving, especially in rain or even wet roads is no longer satisfactory and I wish to improve the performance of the low beams. Really evident when a new car pulls up alongside and I momentarily get spoiled by the illumination that they provide. Realizing that there is nothing comparable performance-wise in the 165x100 form factor, but there should be something I can find to improve the output.
I know better than to fall for the ebay HID conversions, etc. but other than that I don't know what to trust. I found Truck-lite 27010 that appear to be good quality, and they state "Exceeds DOT minimum requirements by an average of 300% low beam & 225% high beam" but how does that compare to the Sylvania halogen sealed beam that are currently installed? Yes I have seen the posts describing the worn out tooling for manufacturing the common halogen sealed beams so at least the Truck-lite build quality should be better, no?
My plan is to:
1. Inspect current headlamp wiring and measure voltage drop. If found subpar (probably will), replace with thicker wire and relays.
2. Obtain, install, aim upgraded low beam headlamps.
I realize that there are likely no newest technology solutions (LED, HID, etc.) for this form factor, as there is not sufficient money in this market niche for the manufacturers to develop product.
Seems like I see the quad 165x100 setups on firetrucks, city busses-- are they all as weak as mine?
Maybe the best solution is the GE Nighthawk? Anybody have actual real-world experience with those?
My plan is to:
