Newb here so please take it easy on me....... Charger is an Xtar VP2 with settings of 3.2, 3.6 and 3.8 volts. The protected Orbtronic 840mah 14500 batteries I bought are rated at 3.7 volts. Which voltage setting should I use? I did find in the description on the Orbtronics site that I should charge them at the .25A setting instead of .5A or 1.0. I'm going to be using them in a Sunwayman V11r. Thank you in advance......
