Imalent
Results 1 to 4 of 4
Thread: Test/Review of LG 18650 HE4 2500mAh (Yellow)
    *Flashaholic* HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/Review of LG 18650 HE4 2500mAh (Yellow)
    Official specifications:
    • Nominal Capacity: 2,500 mAh
    • Nominal Voltage: 3.6V
    • Standard Charge: 1250mA, cut off: 50mA
    • Fast charge: 4000mA, cut off: 100mA
    • Max. Charge Voltage: 4.2 +/-0.05 volt
    • Max. Charge Current: 4000mA
    • Standard Discharge: 500mA
    • Fast Discharge: 10000mA, 20000mA
    • End voltage: 2.5 volt
    • Weight Max.: 47.0 g
    • Operating Temperature: Charge 0 ~ 50C, Discharge -20 ~ 75C
    • Storage Temperature: 1 month -20 ~ 60C, 3 month -20 ~ 45C, 1 year -20 ~ 20C
    This is one of LG's high current and high capacity cell.
    This cell can be discharged down to 2.5 volt, because I stop at 2.8 volt I will not get the full capacity.
    Fairly good tracking and good at handling high currents.
    Conclusion
    This battery is one of the very good high current and high capacity battery types.
    Notes and links
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    Compare to 18650 and other batteries
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Oct 2014
    New Hope, MN
    Default Re: Test/Review of LG 18650 HE4 2500mAh (Yellow)
    Does the lower 2.5v min voltage gain an thing practical over a battery that is designed with a 2.8 minumum voltage? That is, does it possible indicate a more durable cathode design?
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by gofastman View Post
    When using unprotected cells with leds it gives you a better safety margin. Even at low power it is difficult to over discharge a 2.5 volt battery in a light without a boost driver.
    Jun 2010
    South Korea
    Thanks for your excellent review. HKJ!
