I got a XHP70 N2 bin ad made some quick testing. (In 6V configuration)
-Soldered the heat pad to 1/8 square copper tube.
-Built a crude lux meter with a LLS-05A linear light sensor
-Ran the test with icy water cooling.
Here's the data:
The 1/8 copper tube is a bit narrow for the heat pad, next, I will solder the LED on three 1/8" tube side to side so the + and - pads are sinking heat as well.
-Hugo
Here's the data:
-Hugo
