IMALENT new model SA04, IMALENT SA04--LED flashlight w/ variable color temperature.
The main advantages of this all-round flashlight:
Specifications
Utilizes one Cree XM-L2,one Cree XM-L LED and two RGB LEDs with a lifetime of up to 50,000
Multi-functional LCD touch screen display indicate the running level and the remaining power with low-power warning
Constant current circuit, constant output
Electronic reverse battery protection
Effective range of 280 meters
Intensity: 14800 cd
Uses 4xAA batteries
Working voltage: 2.8~8 V
Optimized deep metal reflector maintains great throw distance and spread with an ideal beam pattern
Dimensions: 119.5mm (length) x 43mm (head diameter) x 40mm (tail diameter)
Weight: 208g (battery excluded)
Aerospace-grade aluminum alloy body
Military Specification Type III- hard anodized
Waterproof accords with IPX-6 standard
Ultra-clear tempered glass lens resists scratches and impacts
Tail stand capable- can be used as a candle
Accessories: O-rings, Holster
For more details, please refer to http://www.imalent.com. At present, we are looking for distributors and dealers worldwide, feel free to contact us at [email protected] or [email protected] .
We already have dealers in more than 40 countries, to purchase our flashlights at your local place is recommended. Feel free to contact us if you are unable to find the dealer in your country.
Best regards,
David
Imalent team
SKYPE: imalent_david Email: [email protected]
Specifications
Intensity: 14800 cd
Uses 4xAA batteries
Best regards,
David
Imalent team
