The Fenix-Store
Page 1 of 3 123 LastLast
Results 1 to 30 of 62
Thread: Thrunite Archer V2 (XP-L V6 Cool or XP-G2 Neutral) 1A, 2A, 1C, 2C Series Overview
    Drool Thrunite Archer V2 (XP-L V6 Cool or XP-G2 Neutral) 1A, 2A, 1C, 2C Series Overview
    Warning: More pic heavy than usual.
    Thrunite has sent me a complete set of samples of their new Archer v2 line, including both Cool White (CW) XP-L and Neutral White (NW) XP-G2 versions. As with the recent Neutron series, the battery configuration is identified in the model number (i.e. 1A is 1xAA, 2C is 2xCR123A, etc.).
    I have on hand for this review the Archer 1A CW/NW, 2A CW/NW, 1C CW/NW, and 2C (CW, as there seems to be no NW version as yet).
    As usual, I will start with a description and overview of the common build, user interface and circuit functions. I will then provide detailed testing and comparison of each model relative to its respective peer groups. To keep the review size down, I will just use representative build pictures from among the different models. But there is no way around it – this is going to be a long one. Buckle up …
    Common Archer v2 Series Specs
    • LED: CREE XP-L V6 (Cool White - CW) or XP-G2 (Neutral White - NW)
    • Upgraded version of the Archer with more user-friendly UI and updated LED.
    • Added side switch for easy operation.
    • Five modes: firefly, low, medium, high and strobe.
    • Momentary “forward clicky” tactical switch.
    • Stainless steel strike bezel for defense and emergency applications.
    • Reversed polarity protection system prevents damage to the light.
    • Smooth peel reflector for a high quality beam.
    • Ultra clear tempered glass lens with anti-reflective coating.
    • Aircraft grade aluminum body structure with tactical knurling for firm grip.
    • Premium type III hard anodized anti-abrasive finish.
    • U shape groove at the tail for easy activation as well as preventing accidentally activation.
    • Reversible and removable stainless steel pocket clip with titanium coating for durability.
    • Memory function to set any mode (except for strobe) for immediate use.
    • Impact resistant: 2 meters.
    • Waterproof to IPX-8 Standard (1.5meters)
    • Accessories: pocket clip, spare O ring, lanyard
    1A Specs
    • CW Modes & Run-time: Firefly:0.055lumen(408hours); Low:17lumen(22hours); Medium:75lumen(5hours); High:180lumen(115minutes); Strobe:180lumen(3.5hours).
    • NW Modes & Run-time: Firefly:0.42lumens(408hours); Low:15 lumens(22hours); Medium:70 lumens(5hours); High:175 lumens(115minutes); Strobe:175 lumens(3.5hours).
    • Working voltage: 0.9v to 4.2v.
    • Battery: 1 AA or 14500 battery (not included).
    • CW Max beam distance: 71 meters.
    • CW Peak beam intensity: 1261cd.
    • NW Max beam distance: 97 meters.
    • NW Peak beam intensity: 2400cd.
    • Weight: 60g without battery.
    • Dimensions: 110mm in length, 23mm bezel diameter.
    • MSRP: $30 (NW), $37 (CW)
    2A Specs
    • CW Modes & Run-time: Firefly:0.055lumen(672 hours); Low:17lumen(96 hours); Medium:75lumen(11 hours); High:450lumen(100 minutes); Strobe:450lumen(140 minutes).
    • NW Modes & Run-time: Firefly:0.11lumens(672 hours); Low:15lumens(96 hours); Medium:69lumens(11 hours); High:430lumens(100 minutes); Strobe:430lumens(140 minutes).
    • Battery: 2 AA batteries (not included).
    • CW Max beam distance: 130 meters.
    • CW Peak beam intensity: 4232 cd.
    • NW Max beam distance: 161 meters.
    • NW Peak beam intensity: 6560cd.
    • Weight: 75g without battery.
    • Dimensions: 160mm in length, 23mm bezel diameter.
    • MSRP: $30 (NW), $40 (CW)
    1C Specs
    • CW Modes & Run-time: Firefly: 0.055lumen(168 hours); Low:17lumen(11 hours); Medium:75lumen(200 minutes); High:500lumen(40 minutes); Strobe:500lumen(50 minutes).
    • NW Modes & Run-time: Firefly: 0.17lumens(168 hours); Low:17lumens(11 hours); Medium:71lumens(200 minutes); High:418lumens(40 minutes); Strobe:418lumens(50 minutes).
    • Battery: 1 CR123 or 16340 battery (not included).
    • CW Max beam distance: 124 meters.
    • CW Peak beam intensity: 3870cd.
    • NW Max beam distance: 158 meters.
    • NW Peak beam intensity: 6310cd.
    • Weight: 52g without battery.
    • Dimensions: 94mm in length, 23mm bezel diameter.
    2C Specs
    • CW Modes & Run-time: Firefly: Firefly: 0.26 lumens(69 days); Low: 14 lumens(128 hours); Medium: 184 lumens(11 hours); High: 840 lumens(125 minutes); Strobe: 840 lumens(340 minutes).
    • Working voltage: 2.6-8.4V.
    • Battery: 2 CR123 or 16340 batteries or one 18560 battery.(not included).
    • WEIGHT: 66g without battery.
    • Dimensions: 128mm in length, 24mm bezel diameter.
    • MSRP: $40 (CW)
    Packaging is the same for all models, and includes a hard cardboard box with packing foam (a sticker on box indicates cool white or neutral white). Inside, you will find the light (with pocket clip installed), extra o-rings, extra boot switch cover, basic wrist lanyard, and manual.
    Note that Thrunite has recently updated their warranty policy for all lights, available here.
    As with other series reviews, I will start off with a discussion of the common physical build and user interface/circuit functions. I will then provide separately (by model) beamshots, testing measures and runtimes.
    Common Build
    Here are a series of general pics:
    Archer 1A:
    Archer 2A:
    Archer 1C:
    Archer 2C:
    Physically, the new Archer lights are very similar to one another. Indeed, it is just the 2C that has a wider body (to accommodate the thicker 18650 cells) – the heads look the same across all models. All lights feature a classic tailcap clicky-switch for on/off, as well as side electronic switch for mode changing.
    All lights have knurling, which is of reasonable aggressiveness, and glossy black anodizing. Hand feel is good, and the included clips help with grip (and serve as anti-roll).
    The tail-switch is a typical forward clicky switch, with a raised surround (that serves as a lanyard attachment point and allows stable tailstanding). The side-mounted electronic switch protrudes slightly, and has a definite "click" (with typical traverse). The center of the switch is clear, but there doesn't seem to be an LED indicator underneath (as there is on some of the other recent Thrunites).
    The only difference inside the lights is on positive contact board in the head – the 1A, 1C and 2A models have the classic reverse-polarity feature seen on many AA lights (i.e., only small button top can be used). The 2C lacks this feature, and so will take flat-top cells just fine.
    Screw threads are square-cut and anodized, allowing lock-out on all models. Oddly, there are some differences in the tail threading, and only the 1A and 2A have interchangeable tailcaps.
    The new Archers use a crenelated bezel design, in stainless steel. Reflectors are smooth finish, and appear to be identical across models and emitter. Centering of the emitters was reasonably good on samples (although not perfect). The Cool White versions come with the XP-L emitter, the Neutral Whites the XP-G2.
    Scroll down for specific beamshot comparisons for each model/battery config.
    Common User Interface
    Turn the lights on/off by the physical tail switch. Switch is a forward clicky, so press and hold for momentary on, click for locked on.
    You change modes by use of the side electronic switch. Click (i.e., rapid press release) to advance through modes. Mode sequence is Firefly > Lo > Med > Hi. There is a "hidden" Strobe mode accessible by a press-and-hold of the side switch.
    The light has mode memory for the constant output modes, and retains the last level set when you turn it off/on (i.e., no memory for Strobe).
    Video:
    For information on the lights, including the build and user interface, please see my video overview:
    As an aside, if you want to get an instant notification for every new review that I post here on CPF, you can subscribe to my YouTube channel (the vids go public at the same time). Just mouse over my logo watermark on the video for the subscribe feature to open up. You may need to tap or click, depending on the platform you are using to watch.
    PWM/Strobe
    The new Archer v2 series lights are current-controlled on all modes – there is no indication of pulse width modulation or circuit noise on any constant-output mode, on any model.
    Strobe is a consistent 12.8 Hz on all models, although there is variation in how the oscilloscope traces looks:
    Archer 1A CW:
    Archer 2A NW:
    Archer 1C CW:
    Archer 2C:
    None of this is visible to the naked eye – in all cases, strobe is a consistent "fast" strobe across this series.
    No Standby Drain
    Since the Archers all have a physical clicky switch, there is no standby drain when the lights are off.
    Throw/Output Summary Charts:
    Individual Comparisons
    Archer 1A – 1xAA/14500
    From left to right: Panasonic Eneloop Pro NiMH AA; Thrunite Archer 1A, Olight S15R; Zebralight SC52; Sklihunt DS15; Fenix LD12; Armytek A1.
    Thrunite Archer 1A v2 CW: Weight: 66.9g, Length: 109.6mm, Width: 23.1mm
    Thrunite Archer 1A v2 NW: Weight: 66.8g, Length: 109.3mm, Width: 23.0mm
    Thrunite Neutron 2A 2014 (1xAA form): Weight: 57.6g, Length: 95.6mm, Width (bezel): 25.6mm
    Thrunite T10S: Weight: 60.9g; Length: 93.7mm, Width (bezel): 17.8mm, Width (widest): 18.7mm
    Fenix LD12: Weight: 52.3g, Length: 99.9mm, Width (bezel): 21.6mm
    Nitecore MT1A: Weight: 54.6g, Length: 104.6mm, Width (bezel): 22.7mm
    Nitecore SENS AA: Weight: 26.1g, Length: 82.7mm, Width (bezel): 19.8mm
    Olight S15R: Weight: 47.6g (69.2g with Olight 14500), Length: 89.6mm, Width (bezel): 23.1mm
    Olight S15: Weight: 46.4g, Length: 87.0mm, Width (bezel): 23.1mm
    L3 Illumination L10: Weight: 20.7g, Length: 79.4mm, Width (bezel): 17.1mm
    Lumintop ED15: Weight: 59.7g, Length: 100.2, Width (bezel): 21.9mm
    Skilhunt DS15: Weight: 52.0g, Length: 92.1mm, Width (bezel): 24.0mm
    Xeno E03:: Weight: 48.1g, Length 96.7mm, Width (bezel): 21.5mm
    Zebralight SC52: Weight 39.5g, Length 79.0mm, Width (bezel): 22.6mm, Width (max) 25.4mm
    For white-wall beamshots below, all lights are on Max output on an NiMH or 14500 AA-sized batteries. Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). For NW lights, a Daylight white balance (on my Canon) is used to provide a more consistent visual comparison to the CW lights.
    Note that "2A 2014 1xNiMH" below refers to the Neutron 2A 2014 in 1xAA form.
    In the interest of space, scroll down to the 1C RCR beamshots if you want to get an idea of what 1x14500 in the 1A looks like.
    Archer 2A – 2xAA
    From left to right: Panasonic Eneloop Pro NiMH AA; Thrunite Archer 2014, Neutron 2A 2011; Neutron 2A 2014; Eagletac D25A2; Olight S15 with extender, Olight ST25.
    Thrunite Archer 2A v2 CW: Weight: 80.0g, Length: 159mm, Width: 23.0mm
    Thrunite Archer 2A v2 NW: Weight: 79.7g, Length: 159mm, Width: 23.1mm
    Thrunite Neutron 2A 2014 (2xAA form): Weight: 73.46g, Length: 146.2mm, Width (bezel): 25.5mm
    Eagletac D25A2: Weight: 54.8g, Length 148.5mm, Width (bezel): 21.0mm
    Foursevens QAA-2 X (Tactical tailcap): Weight: 60.1g, Length: 149.1mm, Width (bezel) 22.0mm
    Jetbeam BA20: Weight: 70.2g, Length: 156.4mm, Width (bezel) 23.2mm
    Nitecore MT2A: Weight: 66.9g, Length: 154.3mm, Width (bezel):22.7mm
    Nitecore EA2: Weight: 68.9g, Length: 134.4, Width (bezel): 26.1mm
    Olight ST25: Weight: 76.1g, Length: 152.4mm, Width (bezel): 23.0mm
    Olight S15 2xAA: Weight: 59.2g, Length: 137.9mm, Width (bezel): 23.1mm
    Sunwayman D20A: Weight 118.4g, Length: 102.6mm, Width (head) 20.9mm, Height (head) 35.1mm
    For white-wall beamshots below, all lights are on Max output on 2xNiM AA (Sanyo Eneloop). Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). For CW lights, automatic white balance is used on the camera, to minimize tint differences. For NW lights, a Daylight white balance (on my Canon) is used to provide a more consistent visual comparison to the CW lights.
    Note that "2A 2014" below refers to the Neutron 2A 2014 in 2xAA form.
    Archer 1C – 1xCR123A/RCR
    From left to right: Rayovac CR123A; Thrunite Archer 1C; Olight S10R; Skilhunt DS10; Foursevens QTLC; Eagletac D25C; Armytek C1.
    Thrunite Archer 1C v2 CW: Weight: 59.9g, Length: 93.9mm, Width: 23.1mm
    Thrunite Archer 1C v2 NW: Weight: 59.2g, Length: 93.9mm, Width: 23.1mm
    Thrunite Neutron 2C 2014 (1xCR123A/RCR form): Weight: 63.0g, Length: 87.7mm, Width (bezel): 25.5mm
    ArmyTek C1 XM-L: Weight: 43.0g, Length: 80.2mm , With (bezel): 23.1mm
    Eagletac D25C Clicky: Weight: 30g, Length: 76.0mm, Width (bezel): 20.0mm
    Foursevens QTLC: Weight 36.4g, Length 84.1mm, Width (bezel) 22.1mm
    Jetbeam PC10: Weight: 50.5g, Length: 93.6mm, Width (bezel): 22.6mm
    Lumintop ED11: Weight: 44.1g, Length: 83.7, Width (bezel): 21.8mm
    Olight S10 (2013, XM-L2): Weight: 40.5g, Length: 70.8mm, Width (bezel): 23.1mm
    Skilhunt DS10: Weight: 47.0g, Length: 76.1mm, Width (bezel): 24.0mm
    Sunwayman C10R: Weight: 57.3g, Length: 76.2mm (no lanyard plug), 82.3mm (with plug), Width (bezel): 25.6mm, Width (head at widest part): 28.6mm
    For white-wall beamshots below, all lights are on Max output on an AW protected 18650 battery. Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). For NW lights, a Daylight white balance (on my Canon) is used to provide a more consistent visual comparison to the CW lights.
    Note that "2C 2014" below refers to the Neutron 2C 2014 in 1xCR123A/RCR form.
    1xCR123A
    1xRCR
    Archer 2C – 2xCR123A/RCR, 1x18650
    From left to right: Keeppower Protected 18650 3100mAh; Thrunite Archer 2C, Neutron 2C 2014; Olight S20R, 30R; Zebralight SC600-II, Nitecore P12
    Thrunite Archer 2C v2 CW: Weight: 66.3g, Length: 128.1mm, Width: 23.0mm
    Thrunite Neutron 2C 2014 (2xCR123A/RCR form): Weight: 71.2g, Length: 117.7mm, Width (bezel): 25.5mm
    Thrunite TN12-2014: Weight: 80.0g, Length: 140.5mm, Width (bezel): 25.4mm
    Eagletac D25LC2: Weight: 50.0g, Length: 116.3mm, Width (bezel): 22.5mm
    Eagletac S200C2vn (V54 mod): Weight: 168.7g, Length: 155.0mm, Width: 47.0mm
    Fenix PD35: Weight: 82.7g, Length: 138.1mm, Width (bezel): 25.4mm
    Olight M22: Weight: 148.4g, Length: 144.8mm, Width (bezel): 41.2mm
    Nitecore P12 2015: Weight: 88.7g, Length: 139.5mm, Width (bezel): 25.5mm
    Skilhunt DS20: Weight: 53.8g, Length: 110.0mm, Width (bezel): 24.0mm
    V54 Sky Lumens 2: Weight: 83.1g, Length: 119.2mm, Width (bezel): 24.0mm
    Zebralight SC600 II: Weight 79.3g, Length: 101.8mm, Width (bezel) 29.7mm
    Zebralight SC62: Weight: 42.3g, Length: 96.5mm, Width (bezel): 23.2mm, Width (max) 26.1mm
    Note that "2C 2014 1x18650" below refers to the Neutron 2C 2014 on 1x18650 form.
    The side switch button is fairly small, and may be hard to locate by touch alone (even though it is slightly raised).
    All lights show a timed step-down from Hi after ~3.5 mins runtime (except on 1xAA batteries).
    Most models are not driven as highly on max as other recent lights in their respective classes. However, they all produce a reasonable Hi level.
    Ok, that's a LOT of data.
    Let me start with the physical build, since it is fairly consistent across models. Personally, I found the Neutron v2 refresh in 2014 to be a bit "plain vanilla" in styling. As such, I'm happy to see that Thrunite has kept a more traditional design for the Archer v2 update.
    While this design is not particularly novel or innovative, it has the advantage of being familiar and well thought-out (i.e., very similar to a number of Fenix and Olight lights over the years). I like the forward clicky switch (with ability to tailstand), the side switch for mode changing (with low voltage warning underneath), the decent bi-directional pocket clip, the stainless steel crenelated bezel, and the reasonable knurling.
    I like the user interface, with its separation of on/off from mode changing. The mode sequence (and level spacing) is generally good, with strobe mode "hidden" under a press-hold of the side switch.
    Circuit-wise, all models show a good customized current-controlled circuit, with reasonable interface. Output/runtime efficiency is typically excellent - very similar to the Olight and Skilhunt series lights, and the earlier Neutron V2. Regulation patterns are similarly good, with most models (on most levels) showing flat stabilization. Please see the individual runtimes above for more information on the model relevant to you.
    Output levels and beam intensity are generally consistent with Thrunite specs. As a general rule, Hi output increases as you go up to higher voltage sources on any given model, but the Firefly-Med modes remain relatively unchanged. Again, please see my detailed summary tables earlier in this review, for the individual models you are interested in.
    Beam patterns are also good for the series, with a reasonable trade-off between center beam throw and spill. It is nice to see the option of the XP-G2 Neutral White or XP-L Cool White emitter on each model (except the 2C so far). There is not a big output difference on most models (on most batteries), although the NW versions to tend to be a bit throwier (thanks to the smaller emitter die). I am surprised to see how low the prices are for these lights, considering everything you are getting here (especially for the NW versions).
    There really isn't much to criticize here. Thrunite has done good job in providing an extensive series of lights with a consistent interface and build - but customized circuits for best performance. You also get the option of Neutral White and Cool White for each model (except the 2C at present), with a lower price point for the Neutral White version. Frankly, either tint seems to be a bargain for the various battery classes. A very nice series at an even better price - I can certainly see the new Archer series doing very well for them.
    Archer 1A, 2A, 1C and 2C models were provided by Thrunite for review.
    Flashaholic* Ryp's Avatar
    Jul 2013
    Default Re: Thrunite Archer V2 (XP-L V6 Cool or XP-G2 Neutral) 1A, 2A, 1C, 2C Series Overview
    Thanks for the review!
    2C? That light is the only one not on their website, odd.
    Yes, I think that is because the final specs have not been determined yet. The 2C sample I have certainly performs well, as with the rest of the (published) series.
    Jul 2013
    Looks like a good alternative to the P12-styled lights, shorter and narrower than the rest. The only thing I would have liked to see would have been an option for bezel-down carry.
    Well, because of the large loops, the clips all allow bi-directional attachment (granted, not as as securely bezel down). And on the 1C, you could easily reverse the orientation of the clip and still have everything fit.
    What about the energy spent while off? I have heard some issues about it.
    Sep 2010
    Light years away from you!
    God SB. All that data grinding. Surely, you must ask some paycheck from them to perform such extensive reviews Thanks for yet another great review!
    Quote Originally Posted by brtactical View Post
    As Selfbuilt says in the review:
    No Standby Drain
    As Dubois quoted from the review, there is no standby drain in the Archer series (thanks to the physical clicky switch). It is only in lights with electronic switches (like the Neutron series) where standby drains are a potential concern. I typically measure these currents though, and report any potential issues.
    Quote Originally Posted by SuLyMaN View Post
    Yeah, this was a long one. Although it saves a bit of time in the review writing to do one massive review, the bulk of the work is in the testing, analysis, and preparation of the figures and tables. This review has kept me very occupied the last couple of weeks!
    Given the length, please let me know if you spot any errors or inconsistencies. It's hard to ensure the right figure always shows up in the right place ...
    Flashaholic* bladesmith3's Avatar
    May 2012
    colorado springs
    thanks for all you do SB
    Thanks SB for the big review. I know it took a lot of time. It is appreciated by many. I just ordered the 1C NW. It is a little bigger than the SC52 or the S10 I usually carry. It looks more of the size of the PC10 that I use to carry but has been confined to glove box duty. I prefer the side switch but issues arise when carrying. The SC52 is a great little light but I don't like the UI. The S10 is great for night stand use but has to be locked out when carrying. My PC10 is a little sensitive to mode switches on the only switch. The 1C may be a good compromise. Time will tell. The price is reasonably inexpensive and I have always believed that the Thrunite brand is a good value when compared to others.
    Thrunite's current guarantee:
    Hassle Free Guarantee
    1. 30 Days FREE RETURN/REPLACEMENT: Any item bought from thrunite.com/ThruNite Amazon Stores can be returned to get refund within 30 days of receipt in new condition(means the intact condition for sencondary offering) with all included accessories, manuals, warranty card(if any), and combo items if you don't like it.
    Note 1: If anything is missing, a fee of 15% of the order or higher (at our discretion) may be charged. The freight caused in return will be paid by the customer.
    Note 2: Any item bought from thrunite.com/ThruNite Amazon Stores can be returned to get refund or replaced within 30 days of receipt if it is defective. The freight caused in replacement or return in this case will be born on thrunite.com.
    Note 3: The customer should contact with ThruNite immediately if they misordered/changed their minds/want to change any other information when they purchase from thrunite.com/ThruNite Amazon Stores. We will check if the order can be revised or cancelled. If it is shipped out, the customers have to bear the returning fee. Please note we do NOT accept any shipping address change. If you moved, please contact the courier to direct the delivery for you.
    Regarding Note 2: to me it reads that if the product is defective on arrival or becomes defective within 30 days of purchase, Thrunite will pay for BOTH return and replacement shipping. Do you guys interpret it the same way? I was under the impression that the customer would pay for return shipping, even if it was for a defective product.
    Quote Originally Posted by scs View Post
    That is certainly how I read it as well. Of course, you need to request an RMA before sending it back, so they may simply tell you not to bother in that case.
    The link in the review takes you to the rest of the guarantee, for the replacement guarantee (from 30 days to 2 years) and the limited lifetime (beyond 2 years). Note that this all applies to purchases through Thrunite directly or their Amazon store.
    Thanks, selfbuilt. At least for me, that kind of return policy provides peace of mind. In fact it has just removed the biggest reservation that's been keeping me from giving Thrunite products a try.
    Thanks for the review! Thrunite has finally adjusted the mode sequence between the last and 2nd. It used to be 600-800 to 1000 lumens which is quite pointless.
    Quote Originally Posted by Kalpn View Post
    Yes, I'm so glad they didn't include that redundant turbo mode. I think some of their flashlights have it simply for marketing purposes (our light is brighter than the competition for a few minutes).
    I have two Archer 1A V2 NW's and I can attest to their quality. They quickly became my favorite lights. Beam profile and tint are excellent. It's amazing how well they can perform on a single AA.
    The Archer 2C V2 looks very promising. Here's hoping the NW version will come with an MT-G2 emitter
    Thrunite has just added the specs for Archer 2C V2CW.
    Specifications:
    - LED: CREE XP-L V6 LED with a lifespan of 20+ years of run time.
    - Modes & Run-time: Firefly: Firefly: 0.26 lumens(69 days); Low: 14 lumens(128 hours); Medium: 184 lumens(11 hours); High: 840 lumens(125 minutes); Strobe: 840 lumens(340 minutes).
    - Max output: 840 lumens using one 18650 battery.
    - Max run time: 69 days (Firefly mode)
    - Working voltage: 2.6-8.4V.
    - Battery: 2 CR123 or 16340 batteries or one 18560 battery.(not included).
    - Max beam distance: 124 meters.
    - Peak beam intensity: 3870cd.
    - Impact resistant: 2 meters.
    - Waterproof to IPX-8 Standard (1.5meters)
    - WEIGHT: 66g without battery.
    - Dimensions: 128mm in length, 24mm bezel diameter.
    Accessories:
    1. pocket clip
    2. spare O ring
    3. User's manual x1
    4. Lanyardx1
    Yes, I made a similar point in another thread - the slightly lower max output on the Archer is not really an issue, given the decent spacing. A lot of people have queried the Hi/Turbo difference on the TN12 for example (i.e., you don't really see it once the batteries have lost some capacity).
    So they have, just updated the main post.
    The center of the switch is clear, with a red LED indicator underneath (i.e., similar to some of the recent Olights).
    Is there really an LED under the button? I've never seen any low voltage indication on my Archer 1A V2s. Maybe some models have it and others don't?
    Quote Originally Posted by avernite View Post
    You know what, I'm not not sure now. I thought I had seen that in one of the runtime tests, but I have been putting a lot lights through my lightbox recently. I know there wasn't any sign of it for sure on the 1C, since I was looking at that light when it was nearly dead. Let me double-check the others.
    EDIT: Just checked, and none of the the lights seem to have a low-voltage feature. I will edit that line in the review.
    Those stainless steel striker bezels. I've taken my Archer 1A V2s on some night time hikes and now I've got holes in both my front pockets. Could be an issue for people who intend to pocket-carry these lights.
    Tint Snob
    Got my 1c v2 NW today from Amazon/Thrunite. I have several Thrunite lights and they have all been great. This one not so much. Opened up the package put in a RCR turned it on, went through the modes then left it on high as I do all my new lights and check the temp of the body at different times. Between 1 and 2 minutes on high the light shut down. I had to cycle the tail switch to get it to come back on. After another minute it shut down again. Replaced the RCR with another RCR and the same thing happened. Put in a CR and it worked fine. After about 3 1/2 minutes it throttled back like SB stated. I completely drained the CR and the light worked fine. Put in another freshly charged RCR and it shut down in about a minute. That was it for me. It is now boxed up to return. I have always liked Thrunite and believe I just got a bad sample and understand these things do happen. Not sure if I will order another one. The NW tint looked great. Warmer than my S10 L2 NW.
    Flashaholic* InfinitusEquitas's Avatar
    May 2011
    20 Minutes From NYC
    @Selfbuilt - Can you please confirm, it looks like there is a blue O-ring underneath the glass, between the reflector and and lens?
    This was an issue I took with the previous version of the Archer 1A, bought directly from Thrunite... there was no o-ring seal in the head, and the second o-ring they included was too small to put there.
    2xX60vn, 2xMM15vn, Eye40vn, RC40vn, 5xTK75(4vn), FF4, TK76vn, BTUvn, 12XML2 7000l, 3xX40(1vn), Mvn, MX25L3vn, SX25L3vn, TN35vn, 2xS6330vn, EA8 MTG2 OLVN, 2xTN31vn, 2xK50(1vn), 2xTK61(1vn), Xvn.
    Quote Originally Posted by InfinitusEquitas View Post
    Here's a good view of the blue C-ring/ U-ring.
    Scroll down some.
    http://blog.goo.ne.jp/corazon3/e/6a9...8f3db13ccab0a3
    May 2011
    20 Minutes From NYC
    Scroll down some.
    That answers that question, thank you!
    I had a very nasty exchange with them after purchasing my light, asking for an o-ring to put in there, and not getting anywhere with whoever handles it. Was an otherwise good light, but it was annoying to have to find an o-ring on my own to fit in there, and the fit was lousy.
    Quote Originally Posted by gkbain View Post
    That's too bad, hopefully it is a one-off incident. Certainly no issues with either of my Archer 1C samples.
    FYI, I showed the 1A NW around to a group of local flashlight enthusiasts last night (mainly customs fans), and they were quite impressed with the light for the price. Thrunite has done an excellent job in putting together a nice package here (including the circuit, which often suffers in some other builds).
    @Selfbuilt - Can you please confirm, it looks like there is a blue O-ring underneath the glass, between the reflector and and lens?.
    Yes indeed, they were all present on my 7 samples. I remember once receiving a light from a different maker without the o-ring in the head, and it was a pain to find a replacement size. Odd that they didn't have one to ship out to you.
    Thrunite has just added the specs for Archer 2C V2CW.[B]
    That seems kind of low for some reason, at least with the type of batteries that's being used.
    May 2011
    20 Minutes From NYC
    Thing is, my light was directly from Thrunite, and they still would not admit to any problem even after I sent them pictures and explanation of why an o-ring is important, and that the spares they include for the tailcap are too small. Guess they finally got one complaint too many about it.
    Even if the included spare o-rings had been the right diameter for the head, they would not have been an equal replacement for your missing o-ring. I think the u-shape cross section of the o-ring in the head actually wraps over the edge of the lens, top and bottom, cushioning the bottom of the bezel against the lens and perhaps even providing a better seal.
    Some lights have a L-ring for the lens to sit on, and then there is an O-ring embedded into a groove on the underside of the bezel. So the lens is sandwiched/cushioned between to seals.
