Hi, this is my first time here. I have an old fiber-optic light source for a portable medical microscope. It uses an Osram xenophot 64634 HLX EFR 15V 150W GZ6.35 base bulb. The bulbs are expensive, fragile, and don't last long. The socket for the base pins burn out and corrode from heat. The source has a heavy transformer in it and so is awkward to move. I was wondering if there are LED components I could assemble to replace this light source and have comparable light. It also needs to be dimmable.
Thanks for any advice.
That bulb will be about 2500-3000 lumens ....essentially an MR16.
Coupling efficiency is likely on the low side, but that gives you a give start for how many lumens to start with. Without knowing the exact optics it's tough to know exactly what to suggest, but I expect you have a fairly simple setup with a lens in front of the bulb to concentrate on the bundle. You want fairly smooth illumination across the bundle, so you do end up throwing away light.
I expect you have about a 6mm bundle as would be typical for those lights.
The Cree CXA1310 has a 6MM diameter lit surface .... butt that up as close as possible (but not touching) the fiber optic, and you could likely get >80% coupling. Unfortunately you would be limited to about 1000 lumens at 93CRI, 3500K or 1200 lumens at 4000K, 80CRI. Going with a higher CCT will give you a better color gamut which can be useful. Depends what you are looking at.
The XML2 can have as high an output, but optically coupling will be more difficult. Luminous devices are not in the CCT you are likely looking for.
Actually now that I think about it, the
http://cree.com/~/media/Files/Cree/LED Components and Modules/XLamp/Data and Binning/ds MHDG.pdf
The new MHD-G would be absolutely perfect. It has the right source size, lots of CCT/CRI options. Find an off the shelf board and heat sink, and you could simple drive the LED with a dimmable LED driver, or cheap adjustable current power supply.
Semiman
