Justintoxicated
hey guys heres a few pics of the progress im making on my atv project...Just have to make a couple more solders and drill a few more holes to mount it.
The double mount is the housing for 2 Red 1 watters, and the other brackets will support the blue 3 watters...I think im going to use thermal epoxy on them to help disipate heat from the HS.
The red setup will be used for a taillight, and the blues will be mounted on the underside of my atv plastcs, one in the fron't one in the rear to produce a blue glow wherever I may ride /ubbthreads/images/graemlins/smile.gif Hopefully ill get to light them up tonight, thats the plan anyways.
The project box contains a current limiting circuit that converts and stabalized AC to DC then feeds the LED's their proper current. They flicker a bit when the bike is not reved because the voltage on the bike varies with RPMs, and the voltage and current are constantly changing.
Im hoping these LEDs will take the abuse better than the neons everyone else uses. I have had bad luck even with strobes in the past because the circuit boxes they come with don't support the vibrations and eventually the circuit falls apart.
